i've jus swapped from drums to discs on the front of my '82 mini.
the driveshafts came out no bother...i swapped the ball bearings over and slotted the drive shafts back in...no probs!
anyway...i've got the car up on axle stands and ran the engine changing gears...
the passenger side is turning alot faster than the drivers side...
is this normal or should both sides turn at the same speed!?!
Drivshafts
rod998
, Mar 18 2008 06:51 PM
6 replies to this topic
Posted 18 March 2008 - 06:51 PM
Posted 18 March 2008 - 06:57 PM
they most proerly will with the weight back on them, the power goes to the one witht the least grip!!!
Posted 18 March 2008 - 06:58 PM
i think the only way you will know for sure is by taking it for a test drive, and seeing if it pulls to one side or runs nice and straight.
Posted 18 March 2008 - 07:02 PM
sounds like a plan..i think the only way you will know for sure is by taking it for a test drive, and seeing if it pulls to one side or runs nice and straight.
Posted 18 March 2008 - 07:09 PM
thanks. will give it a shot!
Posted 18 March 2008 - 07:12 PM
let us all know if it's ok or not...
Posted 18 March 2008 - 07:40 PM
just found out its the differental...so this is normal! obviously not to strip the gearbox, so should all work fine!
