niggling problem!
Mr Clubman
, Apr 27 2005 10:02 AM
10 replies to this topic
Posted 27 April 2005 - 10:02 AM
Ok...this has very little to do with mini's par se but It is affecting my mini!
Stupidly I changed the plastic tyre valve caps for some groovy aluminum ones around two months ago, but I cant get the blighters off now! tried WD40 and pliers but no luck....I need to put some air in the front tyres. ANY IDEAS? I know I'm stupid!
Posted 27 April 2005 - 10:24 AM
Use a .45 Magnum?!
Posted 27 April 2005 - 10:30 AM
locally head it, and get some mole grips on it, the only problem you might have is ripping off the valve
Edited by Flappyplasticbits, 27 April 2005 - 10:30 AM.
Posted 27 April 2005 - 10:40 AM
damned stuppid things....i should have known.....the reson why caps are plastic in the first place........hmm mole grips would end up ripping the valve off me thinks in this case........you rechon heating it up would have a difference.........then again rubber wheels in close proximity......gulp!
Posted 27 April 2005 - 10:58 AM
You have rubber wheels? Your car must be nice and quiet to drive!
Posted 27 April 2005 - 11:06 AM
dope....sorry tyres.......english is my second language....sorry....bad translation!
Posted 27 April 2005 - 11:09 AM
You might be able to do it when you have two grips. One for the valve and one on the cap. This way if you turn each in the opposite direction you should be fine.hmm mole grips would end up ripping the valve off me thinks in this case........
MiniMoi
Posted 27 April 2005 - 11:16 AM
have tried this....the rubber on the valves themselves twist and if i lift these up and then clamp the brass valve the valve itself starts to shear....so they are pretty tight.....aghhhhhhh WARNING do not buy aliminium valve caps for your mini unless you put some grease or copper grease on them first!
Posted 27 April 2005 - 01:51 PM
or would it be noisier with all that extra rubber deforming?You have rubber wheels? Your car must be nice and quiet to drive!
Posted 27 April 2005 - 01:58 PM
If you had a dremmel (or similar) you could cut uo the side of the cap on oposite sides, then prize it off. a delicate operation though.
Posted 27 April 2005 - 04:18 PM
Would a nut splitter not do this job?
