R1 Not Selecting Gears
#16
Posted 26 March 2008 - 10:23 PM
#17
Try running it up whilst the car is supported on axle stands.
You may have already tried but it doesnt say you have but apologies if you have
cheers
#18
Posted 26 March 2008 - 10:47 PM
Are you trying to select the gears whilst moving with the engine running or just trying to select them with no motion??
cheers
thanks for that, we were on axle stands giving it some beans. still no joy.
#19
Posted 27 March 2008 - 06:31 AM
Does the gear lever not move when trying to engage 5/6? or move but crunch?
Just a guess It sounds like the selector fork between 5/6 is bent. Its very tricky to try and engage high gears without moving and clutch down. Probable cause of bent selector is forcing the gear or if the bike has been down the road on its gear side.
The common faults are 2nd gear and output shaft bearing unrelated to your problem.
#20
Posted 27 March 2008 - 03:58 PM
Fingers crossed for you that it's something as simple
Ade
Edited by Ade, 27 March 2008 - 03:58 PM.
#21
Posted 27 March 2008 - 04:24 PM
Ade
and me - new selector fork is only 28quid but we're so disheartened at the prospect of having to take everything out to get at the engine
We'll give the once over again tonight and see if we get any progress.
thanks Ade and koss.
#22
Posted 28 March 2008 - 03:51 PM
Bike engines have a wet clutch system (still doesn't make sense to me) and the oil can be very important to how this works. I had oil in mine that took on a mayo type appearance shortly after the car was finished and the inevitable dread set in! The car drove fine didn't have any temperature problems etc associated with with head gasket failure.
Drained it and filled with Silkolene bike oil ( one specially designed to help with the clutch). The clutch felt notabley different afterwards and never saw anything mayo like again (kept checking regularly). Would appear that in my case it was just a small amount of water in the oil system probably from when it was stood for however long after being removed from the bike.
Just a thought as I guess it could affect the gear changing if not lubed properly?
Could be worth a try before ripping it all out and sending the engine back?
#23
Posted 28 March 2008 - 04:23 PM
there could be hope yet then !
assuming we have a dodgy sump full of oil, fully synthetic not blending with previous dregs etc - would this make high gear selection troublesome ? either due to poor clutch of sludge around the gear selector forks?
it has been very confusing - no overheating, starts and revs great, first gear has settled down with adjustments on slector mechanism - just no 5th and sixth.
thanks for the response - gonna get some silkolene +4, plus suitable flushing agent and a new filter from local yamaha dealership in the morning and we'll see what happens.
#24
Posted 28 March 2008 - 06:05 PM
Which particular grade of silkolene oil was it as the website recommends a fully synthetic 10-40 oil.
Edited by markrally73, 28 March 2008 - 06:05 PM.
#25
Posted 28 March 2008 - 07:13 PM
wow - mind reader ! - I went to Yamaha dealership and thats exactly what i got. plus 5 litres of a suitable grade for flushing as recommended by yamaha geezer.
thanks
#26
Posted 28 March 2008 - 07:34 PM
#27
Posted 28 March 2008 - 08:13 PM
Does Pete Know of still have a tub knocking round in his garage?
cheers
#28
Posted 28 March 2008 - 08:31 PM
Due to various problems I never kept oil in the pickup long enough to worry about such things so I ended up just using what the local dealer recommended. Can't remember what it was but it wasn't cheap .
Pete
#29
Posted 28 March 2008 - 09:01 PM
Pete
Not arf - £48.00 for 4 litres
#30
Posted 28 March 2008 - 10:35 PM
Pete
How much!!!!!!!!!!!!!
