attaching a flip front
frostie
, Apr 29 2005 04:29 PM
21 replies to this topic
Posted 29 April 2005 - 04:29 PM
i've just bought a steel flip front, and i'm just considering the best ways to mount/attach it.
I'm going to attach hinges at front, and then bonnet pins in all 4 corners of the bonnet(steel removable)...if i welded a metal plate under the scuttle, would i be able to attach the front by these bonnet pins holding the bonnet to the flip front...but also the flip front to the scuttle?
do you get what i mean?
any ideas appreciated!
Posted 30 April 2005 - 06:08 PM
Best way to do it is with Dzues fasteners on the a-panels, think minispares sell them.
Posted 02 May 2005 - 02:46 PM
will dzus fastners on the a-panel be sufficient?
have most people added any kind of rubber between the seams to lower vibration noises?
Posted 02 May 2005 - 03:03 PM
You can put in some faom or something if you want, but you dont realy need it because the dzus fittings pull it in tight. If you look thru the mags, most of the cars have 2 fasteners on each A-panel.
Posted 02 May 2005 - 04:02 PM
mine has 2 dzus fasteners on each A pannel and for the bonnet i have 4 pins with a 2" width strip across the front thats welded in with 2 pins on it and for the rear theres 2 L shaped brackets bolted to the inner wings again with the bonnet pins on
"LOL cheers rab"
"LOL cheers rab"
Edited by Flappyplasticbits, 03 May 2005 - 04:25 PM.
Posted 02 May 2005 - 05:08 PM
Flappy, mind and drive slow or you might spill your 'pints' :grin:
Posted 02 May 2005 - 05:31 PM
cheers guys!
flappy urs sounds much the same as mine when its done, how did you finish the a panel seam and the wing seams when the flip front is closed? have you placed the finishing strip over the 2 seams like if they were welded and then just remove it when flipping the front?or have you just neatened the seams on the 2 panels?
Posted 03 May 2005 - 04:23 PM
i have a finishing strip on the wing side which when shut fits nicely against the seam of the A pannel
Posted 03 May 2005 - 04:24 PM
sorry about the C**p pic, cars at home and im at uni so its all iv got atm
Posted 07 May 2005 - 02:42 PM
when putting a flip front on...why do people cut away the inner flitch(i think it's called that)??
i've got an auxillary fan so that is attached to the inner flitch isnt it? so i couldn't cut any away?
any help appreciated!
also, are rubber bonnet hooks suitable for the a-panels instead of dzus fastners?
thanx
frostie
thanx
frostie
Posted 07 May 2005 - 04:54 PM
how do the deuz fastners work. i understand the bit with screw head thingy on is on the fg front, but where does the little bar go? do you screw it to some metal or something???
I've just bought 4 and rubber hooks for my front.
Posted 07 May 2005 - 09:57 PM
i'm not positive but i think it sticks out from the a-panel, so that when the front is on it's behind the wing.
are you using the rubber hooks for the bonnet or for the a-panel?
Posted 08 May 2005 - 08:38 AM
The dzus fasteners fit flush with the outer panel and have a locking pin that goes thru the panel and catches a sringy wire thing ont the back of the inner panel, and you twist the fastener to lock it in place.
Posted 08 May 2005 - 08:33 PM
so can anyone guide me about cutting the inner part?
also, do people only cut this inner part away on a "weekend" mini, as i'm thinkin the engine area would get pretty mucked up when it's wet from the spray off the wheels? yes or no?
anyone???
anyone???
Posted 08 May 2005 - 08:43 PM
mines a daily car, i;ve cut mine. just cut the inner wing upto shocker, dont get too close tho the shocker mount needs support from the panel.
may get mucky, but most mini bays do. Allows easier access to work on and remove engine if needed.
