im gonna do a 1330 engine with stage3 head and sw10 cam. according to winsu itll do 99bhp. will a mechanical fuel pump keep up with this? is there an uprated mechanical pump available?
Leonard
, May 08 2005 10:18 AM
2 replies to this topic
Posted 08 May 2005 - 10:18 AM
Posted 08 May 2005 - 10:24 PM
I don't know the specs on the mechanical pumps... but you shouldn't have any problems. Most pumps (Mini or otherwise) can provide MUCH more flow at their rated pressures than the car needs. Your 1330 will consume more fuel, but not likely enough to give you problems.
If you just want a better pump, you can always invest in an aftermarket electrical pump and bypass the mechanical one. They're cool, yes, but not necessary unless you're REALLY racing.
Posted 08 May 2005 - 10:41 PM
my 1330 with a similar spec has no problems! if there is anything the RR will pick it up and wont b difficult to change
