FLYWHEEL REMOVAL
a2lt16v
, May 10 2005 03:19 PM
24 replies to this topic
Posted 10 May 2005 - 03:19 PM
does it just pull off with a puller or is it bolted to the crank shaft as well under the clutch
Posted 10 May 2005 - 03:27 PM
You need a flywheel puller...
Undo the large center bolt, then attach puller with the three bolts, using a breaker bar and appropriate socket, tighten until flywheel shhots off.... mind your feet !
There's a post with some piccies somewhere....
Posted 10 May 2005 - 03:28 PM
i will try that although my puller has claws so i was hoping to grip around the clutch plate
Posted 10 May 2005 - 03:29 PM
i dont quite understand what your asking. to use the puller tou have to take the big nut off securing it to the crank and then remember to take the washer off behind this. then simply attach the flywheel puller and get it off. if its a bit tough bive it a bash with a rubber hammer around the edges just to break the lock it might have
Posted 10 May 2005 - 03:32 PM
thats it
i still have my clutch on the flywheel and didnt know if there were 6 bolts fastening the fly wheel to the crankshaft like on most cars.
but it is obviously just held there on the tapered shaft so i will get pulling tonight
Posted 10 May 2005 - 03:45 PM
ah gotcha,
You realy need one of these....
flywheel puller
It can be done with a three legged puller but you are likely to damage something..
also, make sure the slot is horizontal, cause if the C clip slips on the crank then you are shafted ( pardon the punn )
flywheel puller
Posted 10 May 2005 - 03:51 PM
i just want the fly wheel off even if i have to grind it off. just need the gear box off and i think there is some stuff behind there holding it on
Posted 10 May 2005 - 03:52 PM
loads of it, and also the primary gear....and don't damage the transfer case as you will need that too...
Edited by GuessWorks, 10 May 2005 - 03:53 PM.
Posted 10 May 2005 - 03:57 PM
the more i see of these mins the more i grow to hate the impractacalness
yet they remain so addctive and fun
Posted 10 May 2005 - 04:28 PM
I do recommend getting a puller. I tried getting it off without to no avail. And yeah Mini's are kind of impractical, but as are most english cars.
MiniMoi
MiniMoi
Posted 10 May 2005 - 07:13 PM
we managed to snap a puller trying to get the fly wheel of one of madmax's engines! i wouldnt perosnally use the 3 legged puller as guess works said its more likely to do harm than good! especially with the extreem torques need to get these things off
Posted 10 May 2005 - 07:15 PM
LOL great image.
Posted 10 May 2005 - 07:18 PM
Oh that is superb, defintely one for the caption competition.....
but that would seriously hijack the thread !
Posted 10 May 2005 - 07:36 PM
the fly wheel just came off
Posted 10 May 2005 - 08:18 PM
some people get all the luck !!
:cheese:
Mind you, you're due some after the crack in the diff...
:cheese:
Edited by GuessWorks, 10 May 2005 - 08:19 PM.
