Fitted my KAD quick shift recently and it looks absolutley amazing. However my initial exuberence was soon tamed when i took Delilah up and down the quiet cul de sac as its not taxed insured or mot'ed and found that i can no longer select 2nd gear and when i try to use reverse the car moves about a foot and then pops out of gear?
Havnt tried 4th yet as Delilah currently has no brakes either and i cant go to fast.
Has anybody else had a similar problem with a KAD quickshift and if so how did you remedy it?
I should add that 1st gear and 3rd gear are fine and before i fitted the KAD quickshift i had a cheap and nasty one fitted but could select all gears with that no problems???
Edited by Stewart_GT, 05 May 2008 - 08:21 PM.
