Brakes Wont Bleed
Posted 05 May 2008 - 08:51 PM
Posted 05 May 2008 - 08:55 PM
Posted 05 May 2008 - 08:59 PM
Might be worth seeing if you can get any pressure into the system using a one man bleeding kit (Gunsons Eezibleed is good!).
Posted 05 May 2008 - 09:01 PM
Posted 05 May 2008 - 09:09 PM
right i have bled the system the right way starting with the furthest away from the master there could be air left in there but therews no pedal reasistance at all unless i pump the pedal realy fast if i hold it down the its ok doesnt loos any pressure but if let the pedal back up slowly then press down again thers nothig at all and bleeds arnt blocked and calipers have the nipples at the bottom so could be on the wrong way but it should still bleed up thanks for the suggestion any more loli had this problem on my mini, on mine it was because the nipples were blocked, try n poke a dowel up the bleed nipple once loosened, hope this helps!!
Posted 05 May 2008 - 09:12 PM
I'm afraid you're going to need to swap the calipers so the bleed nipples are at the top - that will solve your problem.
Posted 05 May 2008 - 09:21 PM
Posted 05 May 2008 - 09:26 PM
Should find it's a differant story.
Matt
Posted 05 May 2008 - 09:58 PM
ill swap tommorow and try again and i cant clamp the hoses because there all braided thanks for the ideas ill let yopu know tommorowPurple Tom's spot on with this one - swap the calipers and go again.
Matt
Posted 06 May 2008 - 09:01 PM
ok thanks alotevery one changed the calipers around and hey presto thanks alotill swap tommorow and try again and i cant clamp the hoses because there all braided thanks for the ideas ill let yopu know tommorowPurple Tom's spot on with this one - swap the calipers and go again.
Matt
