Hiya,
another common Question on Getting the engine running.
Background:
Fired Engine up on Friday for first time, was running on 3 cylinders
Sunday: got her running on waht i think was 4 cylinders by pushing an HT lead in, hard to tell with the xhaust off
This Morning: Back to 3 cylinders
Later: Backfiring only.
Would like to say:
exhaust is on so is air filter now
All Ignition is Brand new.
Timing is correct
Mixture is'nt great but wouldnt explain the occurances of firing then not and only on 3
earths are new
SO has anyone got any ideas
3 Cylinders, To What I Thought Was 4, To Backfiring.
liirge
, May 06 2008 03:53 PM
8 replies to this topic
Posted 06 May 2008 - 03:53 PM
Posted 06 May 2008 - 04:32 PM
It could be air leaks, stuck valves, lean mixture, bad plugs (yes, I saw you said ignition was new)... the list goes on.
How about starting with putting some form of exhaust on the open pipes. If the mixture is rich and the pipes are open or leaking you can get backfiring.
Posted 06 May 2008 - 04:36 PM
The exhaust is on, i noted that on my first post.
Yer she is running Very lean, well 2 of the plugs say it is, and 2 dont!
Posted 06 May 2008 - 04:38 PM
I was gonna earth the plugs to the block, tomorrow.
Oh yer is this right:
Firing order 1,3,4,2 and they go on the dizzy
Starting from 11:45 going anticlockwise
Posted 06 May 2008 - 05:50 PM
No1 one usually goes on at about 10 past the hour if everything else lined up.
Posted 06 May 2008 - 05:57 PM
OOOh, dear, so the one on the Top right if looking at the Dizzy?
Posted 06 May 2008 - 06:04 PM
Usually. But it depends on the orientation of the dizzy drive spindle.
Posted 06 May 2008 - 06:08 PM
Oh, just to add,
Doubt its a sticking valve as its a new Cylinder head, (Refurb)
Posted 06 May 2008 - 06:11 PM
SO i may have put leads wrong, oh dear
