Is that a little teardrop plate on the second rocker post form the right - to hold the grub screw in? Is this standard fitment? I haven't seen this on either of the two engines that I have.
Posted 27 June 2017 - 12:07 PM
Posted 27 June 2017 - 01:27 PM
Great thread on the rebuild - what camshaft did you end up putting into the engine?
Posted 28 June 2017 - 11:55 AM
found it, part 2A259
Posted 28 April 2018 - 09:38 PM
Time for a long overdue update, a lot has happened since I posted on here, I've moved house and become a father to an awesome little girl.
Now onto the mini, I had it on a rolling road as it just wasn't running right, turns out it was running far too weak this time, was a different beast driving home.
After a bit of use the blue smoke returned once again, this time I thought it must be cylinder head. Before I started taking it apart again I did some digging around, I took the pipes and y-piece off the carbs that come from the timing cover breather, loads of oil!!! Blanked the pipes going to the carbs and went for a drive and no smoke I've left it like that for now until I find a way of connecting a breather filter. Plugs are turning a nice colour and they are dry.
I've taken the film off the rear windows and have got a new rear screen to go in.
Tonight I gave her a polish and some wax
Dave
Edit: First time using imgur, I'll reduce the size of the pictures next time
Edited by davej, 28 April 2018 - 09:43 PM.
Posted 29 April 2018 - 05:33 AM
Looking good Dave! I also resurrected my build thread after a long while, life gets in the way.
Posted 28 May 2018 - 07:45 PM
I've been busy on the mini today, I've got a list of trhings I want to get sorted over the next few months, one of those is to sort the heater and fresh air vents. I have bought some new fancy switches from Wired by Wilson so I thought I'd fit them this weekend.
Another thing I want to get sorted is the speedo has always been about 10mph slower than actual speed. I took the dash out and then split the clocks to find the TPM of the speedo so I can get that sorted. You can`t see it on the photo but its a 1242 speedo, luckily I didn't have to count the teeth.
On to the heater, when I first did the rebuild I hand painted it with hammerite, I thought I`d rub it down and spray it this time. I had to take it apart to replace a leaky matrix anyway. I will give it another couple of coats before I rebuild it.
Then I had a nightmare trying to get the dash back in the car and sitting right between the two dash rails, ended up doing this:
Some longer screws and an extra one for good measure I tried again. Still wasn't happy so I took the dash out and sorted the lower dash rail, these covers are a pain.....
Anyway its back in now and just waiting to hear about a wiring issue for the switch panel and that can go in.
At least it was nice day for it....
Dave
Posted 03 June 2018 - 07:07 PM
Posted 05 June 2018 - 07:10 PM
