Mayfair Rebuild
davej
, May 26 2008 06:38 PM
307 replies to this topic
#31
Posted 25 September 2008 - 08:07 PM
Update:
I now have two genuine inner wings welded in and I`m just waiting to take delivery of a genuine wing and the front end can be completed.
I have stripped all the running gear off the front subframe cleaned it up and painted it. Going to have a good go at cleaning all the suspension arms up and see how I get on as they don`t look too good at the moment.
I have now started to attack the back end and its not good at all, holes everywhere
The rear subframe is now in the skip:
I have cut the old rear valance off and have a new one to go after I`ve sorted the boot floor and replaced the arches:
I now have my freshly bored block back so once I buy a new cam shaft I can start rebuilding the engine.
#32
Posted 25 September 2008 - 08:45 PM
now theres a familiar sight!
#33
Posted 26 September 2008 - 10:15 PM
stirling work and its realy comming on a treat here's a pic to help you along this is my mini 4 years into restoration and I'M 3/4s there now so keep pics comming..................
#34
Posted 27 September 2008 - 11:02 AM
Thanks mate.
That looks great you`re very nearly there now
#35
Posted 23 October 2008 - 04:35 PM
Recently I`ve been attacking the rear end, I have got two new rear archs to put in and have been cutting an old one out:
I am also currently rebuilding the engine after I bought a SW5 cam.
#36
Posted 23 October 2008 - 09:15 PM
looks great mate
#37
Posted 23 October 2008 - 09:24 PM
I guess this is what we should of opted for, rather than a full bootfloor with arches lol
looking good though mate, well done
#38
Posted 23 October 2008 - 11:07 PM
Looking a bit like my mini's twin has similar tin worm as mine Grind Grind spatter spatter ouch ouch > best to poke holes in it now rather than finish it then let the grumpy m.o.t tester do it eh! Just getting stuck into mine its now at work so should be seeing progress too? keep it up looking good
#39
Posted 28 May 2009 - 10:35 AM
Ok so its about time I updated this.
I haven`t been doing much over the winter but have got back to it recently.
The gearbox has been stripped and rebuilt with a different diff ratio and new thrust washers and the like. The block now is built up and just needs bolting onto the box but I`m keeping them seperate for now due to the weight and I haven`t got much space.
Back to the bodywork then, I finally got the inner rear arch to fit (with the help of a trolley jack and blocks of wood )
Genuine repair panel at the bottom of the rear bin:
At the moment I`m just tidying this repair patch up and then will smooth it over with a bit of filler, then its on to the boot floor.
#40
Posted 28 May 2009 - 11:18 AM
Good work matey. love your enthusiasm
wish i had a welder and could do it as well as yourself. ad end up replacing the lot
what mig you got ?
James.
what mig you got ?
James.
#41
Posted 28 May 2009 - 08:36 PM
Cheers mate.
I`ve got a Rand 150S Mig, bought it off ebay last year and once its set up right its great.
#42
Posted 28 May 2009 - 08:53 PM
Great work Dave
#43
Posted 31 May 2009 - 04:21 PM
I have been doing a bit more recently. Ground the welds down and then filled over the repair patch I put in:
I have now cut out some of the boot floor and the boot hinge panel, will weld the new panels in next week hopefully.
#44
Posted 03 June 2009 - 08:06 PM
A quick update.
I have now welded in a repair panel for the o/s corner of the boot floor.
#45
Posted 05 June 2009 - 09:40 AM
nice project keep up the good work
