Just spoke to someone today about a Turbo crank. Ive heard loads of stories about these things but are they actually any different to a standard crank or not?
I think they are tuftrided but im not sure. Is there any way of finding out whether a component has been tufened or not?
Turbo crank or not?
Oldskoolbaby
, May 27 2005 07:48 PM
8 replies to this topic
Posted 27 May 2005 - 07:48 PM
Posted 27 May 2005 - 08:50 PM
Any crank which has been tutrided ( heat treated ) that have a ever so slightly duller surface ( but harder ), I don't know if turbo cranks are much different to any other A+ and when it comes down to it, you can get a crank heat treated for 25 notes anyways so not that special !
Tomorrow or Sunday I'll be able to take a picture of a treated crank which has be splashing around an engine for 30K if you want ! and of cause the state of the bearings...
Posted 27 May 2005 - 09:30 PM
Well the thing is, ive ordered a crank from......well lets not say any names and Ive waited 4 weeks for it. Itll be tuftrided, wedged, bladed, balanced and just about every mod going on an A-Seires crank. Im in a real rush to get mine going so the bloke said if its not back from the tuftriders by tuesday, hell modify a turbo crank for me that he informs me is tuftrided as standard. I trust the block but Ive been ripped off before and I just want to make sure before hand.
Posted 27 May 2005 - 10:24 PM
some people reckon that the early turbo's had forged cranks but this isnt true.
i think the early ones were a bit better than the later ones as they have a different casting number and are darker in colour. but later ones are just standard run of the mill A+ cranks.
i'll try and find the casting number of the early one for you.
i've just got a stock A+ crank in my turbo lump and its fine.
Posted 27 May 2005 - 10:29 PM
CAM6581 is the early turbo crank which is supposedly better
CAM6232 is the normal 1275 A+ crank.
Posted 27 May 2005 - 10:37 PM
Nice one mate. Will that crank run up to just under 9grand though. I definatly want to have a tuftrided crank though just for safety sake.
So do you recon hes telling me porkies. He did say he usually only modifies them for race use as they are so good.
He better not be as I know a few people that use him including some on this forum.
Posted 28 May 2005 - 05:41 AM
A standard crank is good for at leasst 8k rpm, just make sure you get the block strapped if your revving it high.
Posted 30 May 2005 - 01:01 PM
Tuftriding a crankshaft will not enable you to use higher RPM levels. All it does is give the crank a harder surface, meaning it takes longer to wear.
Phil.
Phil.
Posted 30 May 2005 - 01:47 PM
That what I thought. Thing is ill be running a 3.6:1 Final drive so its gunna be a quite revvy motor in general driving conditions fullstop. I take it this will cause it to wear quicker surely.
Thanks for the info though
