If you want an M45 and Bypass Valve contact 1320 Autos. They're a New MINI scrappy and tuner, and Paul should be able to help you out.
Eaton M45 Used To Blow Through A Webber Ideas Pls
mini.cooper998
, Jun 04 2008 09:48 PM
55 replies to this topic
#46
Posted 09 June 2008 - 01:37 PM
#47
Posted 09 June 2008 - 08:27 PM
morspeed seem very competative pricewise
QUOTE
TRACKDAY ENGINE KIT 1293cc TURBO
Running With 15psi boost this engine will produce 140+ BHP. (last tested @ morspeed 15psi 142bhp)
Freshly bored and cross hatch honed to +020, The block is then chemicaly cleaned, Fully prepared & painted, Re-surfaced, Machined for a steel centre main strap, fitted with new cam bearings, Crankshaft is ground to next size, Plasma hardened, Complete with new VP2 Turbo bearings, Conrods are fitted with ARP Bolts, Genuine hepolite 13cc LOW compression Pistons and rings, Supplied with a new Duplex timing gear set, MSPD T2 Performance cam, High grade Followers and Powerflow H/C Turbo oil pump.
Lightened flywheel and up-rated clutch assembly.
Engine is fully dynamic balanced.
Complete with new oil ways, core-plugs & gasket set.
PRICE £830.00 Exchange + £30.00 delivery (uk)
PRICE £980.00 Outright + £30.00 delivery (uk)
Approx time scale of 2 weeks
does anyone know if they do a 1340 version of this
QUOTE
#48
Posted 09 June 2008 - 08:50 PM
its not really worth it but to be honest the more you bore out the more metal your takeing out of the bores obviosly. and less metal means less strenth in the block. id go to 1293 and no bigger as it enables to you retain the block is the bores get scored and for maximum strenth.
#49
Posted 27 December 2009 - 03:31 PM
anyone have any pictures of bini blow through conversions
#50
Posted 01 January 2010 - 11:02 AM
have my carb (turbo su) plenum supercharger and dump valve (standard bini recirc valve) intercooler and pressure reg but could do with a picture or two to give me an idea on plumbing
Any idea
not bad everything in cost me £250 shopping about on ebay
one other quicky
on turbo minis website it shows the fuel return being fed back into the low pressure side of the fuel pump rather than having a tank return.
is this a practical way of doing it (seems ok in theory as any excess pressure will just go back into the tank through the outlet there doesnt seem to be a non return on it and the breather will absorb any pressure change in the tank
any help appreciated
Andy
Any idea
one other quicky
Andy
#51
Posted 01 January 2010 - 11:26 AM
ainanyone have any pictures of bini blow through conversions
save me posting them again ,links to post with pictures and links to diffrerant blow through setups
http://www.theminifo...howtopic=137779
http://www.theminifo...x...119379&st=0
http://www.theminifo...howtopic=144558
#52
Posted 01 January 2010 - 03:45 PM
cheers stig in fairness you are my inspiration and guidance as to why im going supercharged love the injection setup
#53
Posted 01 January 2010 - 04:05 PM
all the pictures look great but all look to be running a remote oil filter. whats the best way of doing this
cheers
cheers
#54
Posted 01 January 2010 - 04:17 PM
well all look like running the normal filter housing to me just running oil coolers thats what the braided lines are going to
for my new engine i hve a mpi block and a maestro bolck as oil filter is in the same place as the mpi but still uses a dizzy
depending on when can get back to work will depend on which i use as will need megajolt with the mpi block but could run dizzy with the other then convert to meagjoilt later on
#55
Posted 01 January 2010 - 09:04 PM
most look to be taking the outlet down where the oil filter would be then across planning on using a cooper s intercooler as fitted to bini almost complete as removed from the bini so will actually be going up anyway so ignore me
ps like the rear mounted alternator what do people recon mpi or bini rewired
#56
Posted 16 January 2010 - 08:37 PM
was tempted with a meastro block but seemed a hell of a lot of work for very little, plus the oil filer will more than likely get in the way of the charger.
has anyone rewired a bini alternator to suit classic and if so how did they do it
cheers
cheers
