Ok , got the top one off easy enough - took the windscreen out.
Is it a case of brute force and perseverance on the bottom one? Cant see any screws on it, is it glued on?
Dash rail removal
vasi
, May 30 2005 11:09 AM
1 reply to this topic
Posted 30 May 2005 - 11:09 AM
Posted 30 May 2005 - 11:13 AM
If you remove the chrome finnishing strip from the top edge, there are a few clips under it and same on the bottom (but no chrome strip on the bottom) Take the clips off then gentle peel it off. Its also glued on, but is ok if you take your time and do it evenly.
