"poo" The 1967 Riley Elf
157 replies to this topic
#16 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,128 posts
  • Name: Sean
Posted 26 July 2008 - 05:39 PM
Well, had a bit of a time with Pooh!!
I decided on Thursday that I wanted him to be MOT'd for the weekend so I stopped in the garage till 11pm Thursday night to get him all welded up.
I also repaired the steering cololum, adjusted the brakes, and generally checked him over.
Attached File  pooh_001.JPG   324.94K   55 downloads
Attached File  pooh_004.JPG   326.85K   69 downloads
Attached File  pooh_003.JPG   331.55K   41 downloads
I'm fairly happy with the result, not a resto job, but strong and fairly tidy.
Anyway, I decided to take him for a quick spin around the block to check him out.
Disaster!!!
The front side passengers wheel felt like it was trying to shake itself off, dammit!
It was too late the check it out so I went to bed resigned to not MOTing him.
I woke up at 6am and realised he had rubber driveshaft joints, which when they wear can make the noise I heard.
Jacked him up and lo and behold, it was knacked.
I decided to risk driving him for an MOT(with AA card), he made it there and turned out to be nice to drive as well.
After about an hour I got I call from the Test station, they couldn't MOT him as they couldn't find his details on the computer, I would have to come in with the V5 to get him tested
GUTTED!!
My late night was for nothing!!
I ordered the new joints and removed the old knacked ones
I think this may be the source of the noise!!!!
I also gave the underside a quick coat of "MOT in a Tin! or underseal!!
I also need to
- give him a service
- Fix Gearlever rattle
- Convert to neg earth
- Fit radio
- Fit minilites
- Fit new tie-bars
Give him a clean and tidy up
#17 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 26 July 2008 - 06:10 PM
Shame about the MOT!
A1 paint job on the floor tough! :angry:
#18 Shifty
Shifty
  • 13,128 posts
  • Name: Sean
Posted 31 July 2008 - 09:30 PM
Have been hard at with Pooh!!
Since my last update I've
- Changed the gearbox remote to improve gearchange
- Fitted uprated Tie bars
- Fitted new drive shaft joints
- Fitted new Wipers
- Refitted carpets
(oh and fitted a new green bulb cover to the stalk)
Attached File  pooh_003.JPG   330.32K   25 downloads
Attached File  pooh_002.JPG   328.41K   23 downloads
And after all this work?
He passed - Pooh has an MOT!!
With the drive shaft fixed and the gearchange sorted he really is a nice drive!!
The engine is a bit "tired" and an oil change and some STP has helped but it will need a rebuild
Jobs to do are
- Positive to Neg Earth conversion
- Fit electronic Ignition
- Give a quick service
- Trial fit minilites
- Fit Radio
I hope to do a lot of these tomorrow!!
#19 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 31 July 2008 - 10:02 PM
- Fitted new Wipers
- Refitted carpets
Jobs to do are
- Fit Radio
we've still got a 1380 bottom end in johns workshop :shifty:
#20 M1N1C00P3R1275
M1N1C00P3R1275
  • 258 posts
  • Local Club: Minifinity
wooo pooooh well done shifty
#21 Shifty
Shifty
  • 13,128 posts
  • Name: Sean
Posted 31 July 2008 - 10:05 PM
Hmm, a 1380 and drum brakes!!!
That sounds like a plan!!
Cidre boy, you're early!!!
#22 M1N1C00P3R1275
M1N1C00P3R1275
  • 258 posts
Posted 31 July 2008 - 10:06 PM
yep i am and drinking scrumpys
#23 giz
giz
  • 747 posts
  • Local Club: ubmc
Posted 31 July 2008 - 10:47 PM
other than that "bit" of rust it looks pretty tidy, i've always wanted an elf and a pick up. i've got the pick up but i doubt i'll be alowed to buy an el any time soon.
which is why i'm so freekin jealous!
good find keep up the good work
:shifty: ;D
giz
#24 roofless
roofless
    Sticker Pimp
  • 7,215 posts
Posted 06 August 2008 - 08:49 PM
in about a week I'll have a spare R1 engine :D
#25 Shifty
Shifty
  • 13,128 posts
  • Name: Sean
Posted 06 August 2008 - 08:53 PM
I'm gonna leave Pooh as standard, I quite enjoy pootling everywhere at 50mph!!
At the moment he's running hot, so have replaced the head gasket, still hot!!
Have just bought him a new rad and water pump, this should cure it(hopefully)
#26 roofless
roofless
    Sticker Pimp
  • 7,215 posts
Posted 06 August 2008 - 08:57 PM
whats the best thing to use to flush a system out and get rid of all the gunk?
#27 Shifty
Shifty
  • 13,128 posts
  • Name: Sean
Posted 06 August 2008 - 09:00 PM
You can buy flushing stuff?
I've back flushed the rad and block as well, still no joy.
to be honest all of the cooling componants look crusty and past their sell buy date so I'm gonna replace em all.
#28 Shifty
Shifty
  • 13,128 posts
  • Name: Sean
Posted 12 March 2009 - 09:01 PM
Poos engine has been getting more and more tired lately, couldn't even muster 25psi oil pressure!!
Anyway I'd decided that once Malvern was out of the way I'd build and fit his new lump.
I'd got all the bits together to build a fruity 998.
Block
Bored +20
Crank ground
New cam Brgs
Hot dipped and cleaned
Cam - Sw5 with Alloy vernier
Head 12g295 - ported with big valves and MG metro valve springs
Flywheel - Minisport ulta light with billet backing plate
New clutch
Gearbox - Guessworks refurb with a 3.44 diff
Carb - HS4 with K an N Filter
Exhaust - Maniflow manifold with a twin box RC40
I'm also going to fit a set of 7.5" brakes to him as well.
I've also got some more goodies for him but more of that later!!
Any hoo heres my goodies
Cleaned and painted
His old engine
I've been busy putting all this together, timing the cam in etc.
Its all looking pretty good as well.
Watch this space!!
#29 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 12 March 2009 - 09:06 PM
Looks very tasty Shifty :D Good luck with it!
#30 Nickh_16
Nickh_16
  • 724 posts
  • Local Club: Pembs
Posted 12 March 2009 - 09:07 PM
that should be a nippy 998!
