ive been looking into turbo's and i have a 1310 engine i was going to rebuild with some tasty little parts to produce a quick little turbo... but ive read a few things and im not sure on the best approach to lowering the compression ratio.
Skimming the pistons is one thing, saving on turbo ones and keeping the higher volume.
the second, which i read about 2day and quite interested in, is head modifying... now this was advertised by minispeed as "head for use with turbo" and looking at the picture it showed one chamber but enlarged and rounded...
now i was wondering if i cud do this and not have to remove the pistons etc, assuming that everything is in perfect order, could i get 8.5:1 CR just by getting a machinest to grind out the chambers?
Prepping For Turbo... Help!
mighty_mini
, Feb 24 2004 01:03 AM
5 replies to this topic
Posted 24 February 2004 - 01:03 AM
Posted 24 February 2004 - 06:24 AM
You can do it yourself , but you will have to do some sums to work out the volume of the chamber you require, grind out the metal with a die-grinder and check out the volume using a big syrige (marked off in cm2)and some parafin , you use a head gasget as a tamplate , I havent tried this myself but am sure i read it in the Visard book .
Posted 24 February 2004 - 07:50 PM
i take it that it means its possible to take enuf off the head to lower the CR? in which case i have a mate who machines for a living, but not got round to asking him if its possible as he's not mini minded as such...
Posted 24 February 2004 - 08:58 PM
Come round to my place on day mate and I'll take you to see the master - Nolan Pitts, he'll know what you need to do and he has templates and calculations for it too...
Posted 25 February 2004 - 07:48 PM
wuill do sometime. how come u aint been on msn much??? if its not too much work overall... you could be seeing a turbo estate... if not, just a weber will have to do
Posted 25 February 2004 - 11:06 PM
I nipped in to see him today and he said go round and he'll talk u thru it, but I will warn u now, he aint a fan of turd-blowers either! But then he's allow an opinion, he's the mini guru!
