Engine Rebuild question
Posted 26 June 2005 - 02:02 PM
Karl
Posted 26 June 2005 - 02:16 PM
Posted 26 June 2005 - 02:52 PM
sounds like it easier to fit a 998 engine complete,
Posted 26 June 2005 - 06:46 PM
Posted 26 June 2005 - 10:25 PM
The 1275 head will most likely need a 998 block to be pocketed otherwise the valve are likely to be having lunch with the block..
Why dont you just replace the big ends in the 1275, it's not like it's a big job and not tha expensive either, 25 quid should see you right for some decent wuality ones.
Piston rings are available for most pistons, but it's getting to the point where it's just as cheap to buy a whole new set of pistons.
As for the other engine components, any of the major mini suplies have vast stocks ( reputedly :cheese: ) os these items, so can be obtained for very few groats.
Edited by GuessWorks, 27 June 2005 - 07:02 AM.
Posted 26 June 2005 - 11:09 PM
Posted 27 June 2005 - 07:02 AM
If it's movement related, it's more likely to be gearbox or drive related
Posted 27 June 2005 - 07:53 AM
Posted 27 June 2005 - 10:55 AM
We could start a sweep on what you'll find when you look inside. I reckon it started with a shattered oil pump anulus and ended up with possibly a holed piston.
Posted 27 June 2005 - 11:04 AM
Posted 27 June 2005 - 03:57 PM
Posted 27 June 2005 - 07:11 PM
The actual root cause could have been as simple as the oil filter needing replacing.
but, in a lighter note, the A series is a fairly indestructable beast and most bits can be replaced, it's only when bits start shooting through the block or gearbox casing you need realy be worried...
Posted 28 June 2005 - 12:37 AM
turned out when i looked at her that when no4 cyl got to TDC it dropped 3 inches, the big end went big styleee, although the gearbox was salvaged and is now in my new engine
