what is the optimum temperature for a performance mini to run at?
performance temp
ministox man
, Jun 26 2005 06:33 PM
6 replies to this topic
Posted 26 June 2005 - 06:33 PM
Posted 26 June 2005 - 11:12 PM
i think its about 70 degrees, if you've got a yellow bible (vizard) its listed in there. Take it that its for a ministock? i like oval racing, go quite a lot mainly to buxton you ever been there?
Posted 26 June 2005 - 11:26 PM
i think its at the 70-80 degree mark, most minis run at this anyway, although when travelling slowly the temp does go up around 90
Posted 27 June 2005 - 03:17 PM
Nah i havent been to buxton irace at arena-essex mildenhall and dover. it is because my mini may be running too cold to get full power as we have a four blade chopper fan on it. Are there any easy ways to heat it up a bit?
Posted 27 June 2005 - 03:34 PM
Change thermostat?
Posted 27 June 2005 - 03:59 PM
only easy way i would have thought would be to change the fan for an 11blade fan or try limit the amount of air flowing over the radiator gills
or as jammy says change the thermostat for one which opens at a higher temp, but i'd just go for changing the fan, i believe the 4 blade fans were used on export minis to hotter countrys, so thats where i'd start
Posted 27 June 2005 - 07:11 PM
i do not have a thermostat but i have a thermostat blanking sleeve it is a two piece fan so if i reduced it to two blades would this push through less air?
