The scuttle is not the easiest panel in the world to replace as it does require the A's and the wings to be removed as well, so is not exatly attractive to ringing. but if the section where the vin is etched is ground/replaced etc then it is going to raise suspisions...
Keeping old number plate when reshelling car
Iain Tyrrell
, Jun 28 2005 12:04 AM
21 replies to this topic
#16
Posted 30 June 2005 - 10:54 PM
#17
Posted 30 June 2005 - 11:12 PM
Hi, Im new on this forum...
So whats the legal situation on my flipfronted mini? who can prove what?
#18
Posted 30 June 2005 - 11:27 PM
I think your only changing the structure in a small % so wouldn't be a problem.
But is your chassis number affected on the scuttle panel?
#19
Posted 30 June 2005 - 11:28 PM
By the way welcome to the forum.
#20
Posted 01 July 2005 - 07:05 AM
If your flip fronting, the area of the scuttle where the vin is etched should be unaffected, unless your removing the raing channel, but you'll end up with a wet engine when it rains.
#21
Posted 01 July 2005 - 06:13 PM
I did a lot of accident cases at my work, and at least here in Holland. They don't even look at the VIN number. They just write it down from the papers. Maybe they should in theory but in practice I have never seen them do it. I think the assume it is correct as it needs to be checked for MOT every year.
Arthur
Arthur
#22
Posted 01 July 2005 - 07:35 PM
If you had to change the scuttle I would suggest keeping all the papers relating to the new panels and work, at least for a few years. Of course if you do just change the scuttle then you aren't changing the identity of the shell so it is perfectly legal (and in fact I think it's a technical requirement) to stamp the original number into the gutter.
