identification of engine
5 replies to this topic
#1 Philtrum
Philtrum
  • 138 posts
Posted 28 June 2005 - 12:27 PM
Hi
I have a metro 12HC 01AA engine in my mini, and its running 13" wheels
Im trying to identify a number of things and struggling so any help is greatfult
the things Im struggling on are
Diff ratio
Compression Ratio
Im sure the speedo is out and I need to know what the diff is etc to try and get the right conversion
the engine has a LCB and full large bore exhaust system, K&N cone type filter and runs sweet but as always, a bit more power would be nice, are there any "quick wins" that I can do to get a bit more go ?
Many Thanks
Phil
#2 Jammy
Jammy
  • 25,397 posts
Posted 28 June 2005 - 12:57 PM
Are you sure its a 12HC? If its a 12HG01 then it will have a 10.1:1 C/R, a 3.11 diff and a catalyst.
Have a look here for an explaination of engine numbers.
#3 Philtrum
Philtrum
  • 138 posts
Posted 28 June 2005 - 01:26 PM
Thanks mate for the reply, its definatly a 12HC
found it listed on a few sites, but no detail
cheers
Phil
#4 Philtrum
Philtrum
  • 138 posts
Posted 28 June 2005 - 08:16 PM
just found this site ....
http://www.mgcars.or...ws/news498.html
it lists the 12hc and loads of others .... unfortunatly it still does not give me any details
any help is greatly received
Phil
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 June 2005 - 10:07 PM
Someone else was looking for this exact same engine just a few days ago.
Turned out to be a 9.75:1 CR lump from a Metro HLE (E for economy meaning it has the 'economy' final drive).
I should say that it wasn't me who found this info the first time round though :sad: .
#6 Philtrum
Philtrum
  • 138 posts
Posted 29 June 2005 - 12:26 PM
Dan
thanks for the info, the CR is better than I thought ... had a feeling it was going to be a real low compression job
any idea where I can find info on the ratio's etc ? (looked on google ... no joy)
I've looked for the other thread you mentioned and cant find it (in case the info was on there)
Phil
