Hi all
I have recently fitted reconditioned radius arms but since refitting the ride height looks a couple of inches too high. Does anyone know if this is normal, I'm just hoping the ride height lowers as I use the car. Any ideas would be a great help.
Jeff
Radius Arm
lersxt
, Jun 28 2005 06:56 PM
4 replies to this topic
Posted 28 June 2005 - 06:56 PM
Posted 28 June 2005 - 07:06 PM
If you fitted new rubber cones then this is perfectly normal.
Posted 28 June 2005 - 07:13 PM
or if the cups the ball fits in to was worn it will be higher :smartass:
Posted 28 June 2005 - 09:52 PM
Mini's always come out higher after you disturb the suspension and as the guys said above new springs or new knuckle joints will increase the effect. Assuming that everything is fitted properly don't worry about it. It'll go down again in a few weeks of driving (usually it's all settled within three months) if it's due to new springs, if it's due to new knuckles just leave it as it's meant to be that high!
Posted 29 June 2005 - 07:57 PM
Thanks all for your help, its put my mind at rest.
Thanks again!
Jeff
Thanks again!
Jeff
