handbrake
18 replies to this topic
#1 miniman5
miniman5
    1 Gold star
  • 3,135 posts
Posted 30 June 2005 - 07:45 AM
hello, ive come to the conclusion that my handbrake needs ajusting, and was lookign through the FAQ's and couldnt find any thing, so maybe it would bne a good idea to put it in there! :grin:
#2 Cir-clipalot
Cir-clipalot
  • 310 posts
Posted 30 June 2005 - 08:43 AM
first make sure the rear drums are adjusted up properly and quadrants not siezed, if the handbrake is still too loose then its the usual arrangement of nut and locknut but its right underneath the handbrake lever in the little bracket welded to the transmission tunnel. Jack rear of car, 4 clicks handbrake up, loosen locknut, tighten primary nut until rear wheels lock, release H/B check rear wheels turn freely, if so nip up the locking nut job done! But deffo do drum adjustment first!!
#3 Pooky
Pooky
  • 5,691 posts
Posted 30 June 2005 - 09:42 AM
While we're on the subject does anyone know what a 'fly-off' hand brake is?
#4 rob mini
rob mini
  • 1,420 posts
Posted 30 June 2005 - 09:45 AM
it would be like this if ur button was permanently pressed in. therefore it wouldnt lock out so you could park but would be used as a driving aid in competition such as rallying :D
#5 Pooky
Pooky
  • 5,691 posts
Posted 30 June 2005 - 09:48 AM
Oh! Good job i didn't buy one then! :D
#6 Purple Tom
Purple Tom
  • 4,921 posts
Posted 30 June 2005 - 09:56 AM
makes things like autotests etc much easier too, no fiddling around with a button on the handbrake!
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 30 June 2005 - 05:34 PM
Almost!
You can lock a flyoff handbrake. It works the opposite to a normal one in that you have to press the button to lock it. If you don't press the button it won't lock so you have a nice rally handbrake but if you do press it then it locks where you leave it. To unlock it you just lift it a little.
#8 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 30 June 2005 - 05:36 PM
stop using it to turn your car :tongue:
#9 Jammy
Jammy
  • 25,397 posts
Posted 30 June 2005 - 06:31 PM
So are fly off handbrakes ok to use instead of the normal one? They're used on the Monty Carlo aren't they, which means they have to be ok to drive on public roads....
#10 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 30 June 2005 - 06:45 PM
fly offs don't improve performance, it just means the handbrake lever doesn't lock in the up position, so you cant use your handbrake to park the car.
The 'old' mod was to drill thru handbrake lever and button (pushed down) and fit an R-pin or split pin, so i'm told by my dad.
dave
#11 Jammy
Jammy
  • 25,397 posts
Posted 30 June 2005 - 06:53 PM
But Dan just said you push the button in to lock it....
#12 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 30 June 2005 - 08:43 PM
They can lock as I said (if you use a proper fly off handbrake pawl not just modify the existing) which means it will hold your car. But technically the MOT requires the handbrake to lock automatically so it's a bit dodgy for legality.
It is true of course that you can modify the handbrake so that it won't lock, but a proper fly off handbrake is new parts to fit into the handbrake lever which changes the mode of the lock.
#13 vasi
vasi
  • 897 posts
  • Local Club: Minis 'n' Oatcakes
Posted 30 June 2005 - 08:50 PM
I wouldnt change my fly-off for a normal one again! You dont realise how much time you lose at the lights by having a normal one. Just tap and go!
#14 Jammy
Jammy
  • 25,397 posts
Posted 30 June 2005 - 09:40 PM
I'm sold!!
#15 marc
marc
  • 2,138 posts
Posted 01 July 2005 - 05:10 PM
OK i want one!! Its always a pain when u dont release the handbrake fully after using it to turn sharply! Slows you down a bit!
Anyone got a link for this? How much?
