Brake Setups
Posted 14 September 2008 - 09:19 PM
Just trying to work out how the cylinders fit (I have ap cylinders for brake and clutch)
Posted 15 September 2008 - 12:23 PM
[attachment=69261:CIMG7550.JPG]
Posted 15 September 2008 - 12:39 PM
This is how I did mine, it sounds like you have the same setup.
Yeah that looks how I thought it would go. Did you have to space the cylinders up or have you used a different pedal box?
I think all I need to get our the bottles.
Posted 15 September 2008 - 12:56 PM
Posted 15 September 2008 - 02:21 PM
I got the reservoirs from Z-Cars and made my own mounting brackets so they'd sit level.
Posted 16 September 2008 - 07:25 PM
the clevis onto the pushrods need shortening as does the pushrod
if you get stuck i can explain easier on the phone what i mean
chris
07786 707734
Posted 13 October 2008 - 07:28 PM
Posted 13 October 2008 - 07:45 PM
Richard
Posted 13 October 2008 - 08:13 PM
I had the same problem with the pipes and just did it by trial and error. The longest one goes from the front to the bias valve. The 2 the same length go from the T-Piece to the rear calipers. The 2nd longest goes from the front right to front left. Which only leaves 2 to work out, master cylinder to front right and bias valve to T-Piece.
Richard
Did you have one for the clutch?
Posted 13 October 2008 - 08:38 PM
Posted 13 October 2008 - 09:01 PM
I'm laying it out in the lounge to see how it all goes.
I've got the two the same going to each rear caliper then to the splitter
a short one from the splitter to the bias valve,
Long one from valve to cylinder
Then i have 4 left.
two with ring holes and two short extensions?
One must go from cylinder to extension to caliper. how does the other connect to right caliper?
Posted 13 October 2008 - 09:10 PM
OK
Then i have 4 left.
The short one with the ring on each end goes from the master cylinder to the right bracket and the the longer one with rings on each end goes across the front. I had to get Richard to send me an additional fixing as I didn't have a double banjo bolt for the front right flexi connection.
Posted 14 October 2008 - 05:23 PM
My kit seems to be different to yours. I dont have any lines with a loop at each end. I can't work out how the left brake joins the right.
Thanks for all your help
Posted 14 October 2008 - 10:12 PM
[attachment=71962:DSC00084.JPG]
Posted 15 October 2008 - 04:59 PM
Sorry I got that wrong, I do have got the same setup as you. It was a T-Piece I got Richard to send, you connect the T-Piece to the flexi and feed into one side from the master cylinder and the other goes to the left hand side.
That makes sense then. But i dont have the brackets on my front frame for some reason.
