My intention was to fit coilovers to my clubman and I was doing ok until I came to fit the front brackets.
Upon inspection we noticed that the old brackets had been welded on soooo thinking that we could just angle grind them and bolt the spax brackets on in replacement we went on with that plan..
How wrong we were, once we got the old ones off we found that the threads for the brackets were well sorta buggered, although some were just a bit delicate and we didn’t want to force them in and risk losing the threads
After finding this out we decided to see what nuts we could get in and weld down the sides…. So my current situation is this:
1. On the passenger side we go the top left and bottom right in but not started welding that yet
2. The drivers’ side is the pain. We managed only to get one bolt in I think on the bottom right or left. My friend tried to weld down the side but he said that it wouldn’t work, can’t remember why something about the metal behind.
So this is where I’m very stuck. My welding friend said we should re-tap the holes for 10m bolts but apparently in order to tap to 10mm bolts you require a 8.8mm drill piece…now where do you get one of them from hmm…
My friend though on the forum supermotolee says that tapping should be the last resort?
I don’t mind paying to get a proper shop to fit them, as W&P are only about 20 mins away (if they can even do it) but how do I transport a car with no front wheels or suspension???
Its like one thing after another and this is my biggest obstacle and to be honest I haven’t got a clue how to even begin to fix it and what’s the correct way to go about doing it
Any advice is appreciated, I know bit of a long post but not to boring to read I hope
(if it goes to a shop I may get them to replace the lower arms and rubbers)
