Daughter Zoe's Mini - Yeah Right!
723 replies to this topic
#571 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,139 posts
  • Name: Sean
Posted 05 July 2011 - 08:19 PM
Nice work as ever steve!!
Isn't it about time you got yourself a new basket case?? Surely you must be itching to get the welder out again??
Heh heh heh!!
#572 CaptainBland08
CaptainBland08
  • 675 posts
Posted 05 July 2011 - 11:22 PM
i think he needs to put those skills to the test engine wise;)
#573 minimuk
minimuk
  • 1,946 posts
Posted 06 July 2011 - 06:46 AM
Excellent work again,..for the last year doing up my mini, I have re-visited your tread very often and picked up some nice ideas, amazing the attention to detail and the "easyness" of finishing touches, and your logic thinking.
Can't wait to see your next project Steve.
#574 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 06 July 2011 - 12:22 PM
Its realy nice, i like the use of the Carbon. Not to OTT :)
Where abouts did you get the wrap?
#575 Zac
Zac
  • 64 posts
Posted 08 July 2011 - 01:54 PM
stevede, everytime i read your thread i get new inspiration! Looks amazing!
I particularly love the "BAD - WORSE - OFF" on the old heater panel, genuine LOL there, hope you wont mind if a shamelessly rip that off for my own heater panel :).
#576 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 08 July 2011 - 06:32 PM
Hi Zac, thanks for your comments. I'll be having a go at pinching your idea on the ignition switch soon so no problems at all.
I'm not using that "BAD-WORSE-OFF" panel any more now I have the carbon.
Drop me a PM with your address and I'll stick in in the post to you.
Regards
Steve
#577 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 08 July 2011 - 06:37 PM
Hi Alex
See below for the carbon bits. Really nice people to deal with.
Made another purchase from them today. All will be revealed soon :(
Carbon Mods - for all things Carbon Fibre
Click Here - Carbonmods.co.uk
www.carbonmods.co.uk
Edited by stevede, 08 July 2011 - 06:37 PM.
#578 Spitfire
Spitfire
  • 59 posts
Posted 16 July 2011 - 09:51 AM
Ohhh what a great job you have done :D)
Ketil
Norway
#579 andyboy!!
andyboy!!
  • 365 posts
Posted 24 July 2011 - 04:15 PM
Hi mate
Great reading your post. I may have missed it as it's such a long read but do you have any more info on the boot section of your car? I'm interested in putting the fog light as you have it and also ditching the standard boot light for some LEDs. Any info\pictures you have would be helpful but no worries if you want to keep it to yourself!!! ;D
thanks
andy
#580 bruders 338
bruders 338
  • 174 posts
Posted 24 July 2011 - 05:08 PM
just read this thread all over again i think its ace..just the way the car been put back properly with what seems like no expense spared.. i would do anything to be able to get the space to do this my self.... i would to strip and rebuild my mini
#581 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 31 August 2011 - 07:46 PM
Hi fellow TMF'ers
A while since I last updated and my first (I think) update on the new forum layout
As always, many thanks for the comments.
So, what have I been up to? Well, apart from working a lot & spending far too many hours on the motorway network, I have been doing a little bit of pottering on the mini.
A few weeks ago, I bought some wooden door cappings in need of a bit of TLC from Pinhead
Wood doesn't go with my interior theme, but then I knew that. - Carbon mods to the rescue !!
Some sanding
And then wrapped in genuine Carbon
I have since coated with the resin, sanded, more resin, sanded again, followed by six coats of laquer.
First attempt so not perfect but they do look mighty fine even if I do say so myself.
Will upload more pictures when I dig them out again.
I have also been doing a bit of modification to the sound system and have some new speakers for the front.
But the best bit.......................................................
Well they say pictures speak a thousand words.
And the fronts?
A little bit of a storey there which I'll not go into now. Suffice to say, they aren't too far away.............I hope!
Will have another update soon
Thanks for looking
Regards
Steve
#582 LouisT
LouisT
  • 197 posts
Posted 31 August 2011 - 08:13 PM
Them seats look spot on...
i was talkin to chris, are they the ones a certain company was trialing?
keep going steve.
cheers, Louis
#583 grahama
grahama
  • 2,442 posts
Posted 31 August 2011 - 08:41 PM
Steve,
bloody awesome pal !!
Graham
#584 R1minimagic
R1minimagic
  • 4,660 posts
Posted 31 August 2011 - 08:56 PM
Steve,
Only 6 coats of lacquer? Don't be slacking now!!
;D
#585 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 03 September 2011 - 06:51 PM
Little additional update after todays work
Thanks for the comments chaps
Louis: Yes those are the ones.
Graham: Many thanks, taken a while but worth it
Dale: I put lots on because I seem to have the habit of rubbing it all away when I flat it back. Looks good now though.
I put the front door cards on today but it meant taking the plasic off that I had used because the butyl strip I used for attaching it was too thick. My pal gave me some offcuts of some stuff they use on joints, that he says will hold the water out.
Door card at the ready
Had to open out the top locating rail as the leather on the door card is much thicker than the old vinyl
Made another small purchase as well..... Top quality :D
Will get the rest either at Stanford if there is an offer or after me hols!
Passenger side as well
Door caps polished and in place. Not sure if I should get black screws or not
And the rears with the caps in place (Chrome trims are on order)
And finally, a slightly better one of the rear without the shadows.
Done the gear & handbrake gaiter as well but didn't get a picture. Will add another day.
And the best bit....................................
Should be picking up the front seats and the dash covers tomorrow which means I'll be going to Stanford in the mini !!!!!!
Will update with more pic's when I get them
Thanks for stopping by
Regards
Steve
