Posted 25 April 2009 - 01:51 PM
Posted 25 April 2009 - 08:24 PM
Well when you do find the voltage regulator, please provide us with some pictures and guidance as my temp gauge stopped working years ago after my coil packed in and fried it (the temp gauge shot up to hot and then hasn't moved since a new coil was fitted).
So I'd love to get my temp gauge working again and the shorting test did nothing on my Mini either.
This is a shot in the dark but has the surge somwhow? shorted out the sender on the bottom of the inlet manifold?
If its shorted to earth it will behave like this.
This circuit does go through the ecu so it may be a good idea to look into this as the car may be running the wrong fuel mixture for the engine temp.
If it thinks its cold when its not it will run too ritch and if it thinks its hot when its cold it will run far too lean.
Both are not good for the engine and performance/economy.
Posted 25 April 2009 - 09:07 PM
Well my 1990 Mini Cooper has a carburettor and no ECU. Plus the temperature gauge sender is mounted below the thermostat as on all earlier Mini models. I've tried the shorting test and even with the ignition on, there was no movement.
Anyway what is that component in the last picture?
Edited by garrett3, 25 April 2009 - 09:10 PM.
Posted 25 April 2009 - 09:28 PM
Ive have the original clocks here and will upload some pictures today.
The white wire to my clocks is a constant 12v... How odd? I can put lights on and run the heater and It still give s asteady 12v.
Thats Why I thought about the ecu.
I'm not trying to say you are wrong I'm just purely stating whats going on with my car.
Edited by Dan, 25 April 2009 - 09:30 PM.
Posted 25 April 2009 - 09:37 PM
Thanks for the pictures, don't worry nobody thinks you're trying to start an argument. I don't mind if I am wrong I'd just like to find out for sure because as you say it is odd.
Yes it's 12v on the white wire but not inside the clocks, that's what the stabiliser does. I guess you've measured that 12v with the engine off? Try it again with the engine on and it will be about 14.2. Try it again with the engine on, the battery fairly low and the lights, wipers and heater running as the car would be in the winter and it'll be somewhere around 12.5. If it really does always read 12v there then I guess it does come from the ECU and the gauges must be designed for 12v. If not there must be a stabiliser and if it's not on the PCB it must be somewhere between the PCB connection and the bimetal heaters in the clock moulding. In fact in the last photo there is a little cluster of components at the bottom right hand edge of the clock moulding as you show it that looks like it might be a stabiliser and might be wired in the way I'd expect the stabiliser to be wired.
Posted 25 April 2009 - 09:42 PM
Posted 25 April 2009 - 09:58 PM
Edited by Dan, 25 April 2009 - 10:09 PM.
Posted 25 April 2009 - 10:11 PM
Posted 25 April 2009 - 10:22 PM
Edited by Dan, 25 April 2009 - 10:54 PM.
Posted 26 April 2009 - 09:31 AM
Edited by garrett3, 26 April 2009 - 09:34 AM.
Posted 26 April 2009 - 10:29 PM
Sorry should have realised it was a carb cooper from the avitar and siggy.
Was just in spi mode lol (been a long few days with this car)
The last picture is of the gauges themselves removed from the clocks housing as taken from the side to show the workings (ie no extra parts?)
You said your needle is in the red right?
What does it do with the ignition off? Does it drop right to the bottom?
Edited by taffy1967, 26 April 2009 - 10:29 PM.
Posted 26 April 2009 - 11:34 PM
Posted 28 April 2009 - 08:06 AM
I have however fixed this!!
Here goes.....
The temp gauge was reading low due to a bad earth on the engine, the temp gauge is on the underside of the inlet manifold on the spi and I ran a couple of resistance checks.
I then ground chean the arm that holds the earth strap and engine steady to the block and fitted some copper slip to keep things good in future.
The engine started sweeter and sounded much smoother and hey presto a temp gauge that reads correctly.
I then thought "but this does not solve my fuel gauge fault??"
So I set about checking the wiring that runs from the front to back and found the connector that joins the rear loom had got wet and was corroded. Spliced in some new connectors and hey presto a fuel gauge that now reads correctly.
Whilst I was there I noticed there is an earth lead that fits to the body just at the back of the ecu but an 11mm bolt, this got the same cleaning and copper slip treatment.
This seemed to help that little bit more too.
My temp is now just perfect on half and the fuel gauge is as accurate as any mini fuel gauge can be lol
Posted 28 April 2009 - 08:07 AM
Posted 28 April 2009 - 08:09 AM
No the temp gauge was in the red just before my original coil completely died and got replaced. Now and since fitting a new coil (some 8 years ago), my temp gauge doesn't move at all and not even whilst trying the shorting the temp sender spade connector against the block test.
So I now take it that I'll need a new gauge as it's not repairable, since there's not an actual voltage regulator that can be replaced?
