Acewell Digi Dash
#16
Posted 19 December 2007 - 01:57 PM
fluctuating but the dash will smooth this out for its own use and will supply a constant VOLTAGE to the sensors
The only way this would change is if the dash goes faulty or your alternator generated a voltage
outside the spec of the dash,in which case everything would be fried.
#17
Posted 19 December 2007 - 02:10 PM
Posted 19 December 2007 - 02:19 PM
by putting resisters across your sender you are calibrating it to suit the dash so i
imagine after some trial and error to get it steady and accurate that will be it in the same way you dont need to keep
adjusting the original mini setup
#19
Posted 27 December 2007 - 09:42 AM
Posted 27 December 2007 - 10:15 AM
#21
Posted 27 December 2007 - 10:32 AM
Posted 27 December 2007 - 02:43 PM
The Smiths stabilizer is really a mechanical voltage regulator. It delivers an "average" of 10V to the gauges it is connected to. As mentioned previously, this isolates the gauges from the fluctuations that occur as the charging system allows the car's operating voltage to fluctuate.
Almost ALL aftermarket gauges have a built in voltage regulator and do not require the Smiths stabilizer. Aftermarket gauges should be connected to a switched +12V supply... one that is off when the ignition switch is turned off.
The sending units for gauges have to be matched to what the gauge was designed for. In the case of the fuel gauge, there are several options (for cars other than the Mini). The typical Mini fuel gauge and sending unit operate between about 240 Ohms (empty) and 30 Ohms (full). You don't need to run your tank dry to confirm this and/or the ability of the gauge and sender to work together. With the gauge connected you can switch on the ignition and use a bent wire through the tank filler neck to push the float all the way down and lift it all the way up. IF you bought a gauge that normally operates between 90 Ohms (empty) and 0 Ohms (full), the parallel resistor mentioned in a previous post will "narrow" the range of the sending unit to match the gauge. There is math involved to explain why this works and how to calculate the exact value you need... suffice it to say that you can narrow a sending unit's output range to match the gauge input... but you can't widen or reverse the direction of a sending unit's output.
If you want to add a Smiths gauge you'll need a voltage stabilizer or a 10V voltage regulator to operate it. There are no exceptions. If you operate a Smiths gauge without the stabilizer it will run at full system voltage (approaching 14V), so it will read as much as 40% high and it will burn out sooner. Take Jupitus up on his offer or download my PDF on the stabilizer and make your own. There are also sellers on eBay who make solid-state stabilizers for British cars.
http://home.mindspri...eStabilizer.pdf
#23
Posted 27 December 2007 - 03:38 PM
#24
Posted 27 December 2007 - 03:51 PM
Again Many thanks
George
#25
Posted 27 December 2007 - 04:12 PM
#26
Posted 27 December 2007 - 10:24 PM
JR
#27
Posted 28 January 2008 - 01:45 PM
Posted 28 January 2008 - 01:58 PM
#29
Posted 28 January 2008 - 03:47 PM
Posted 28 January 2008 - 04:00 PM
