Gear Shift Selector Seal Removal
Posted 09 January 2011 - 09:49 PM
I'm using the smallest screwdriver I could find. What size did you guys use? How should I remove it from the center and not the outside? I'm all out of ideas. =(
Any suggestions would be so helpful.
Stuck seal,
anthony
Posted 09 January 2011 - 09:55 PM
One of these works wonders, and a 17mm socket helps to seat the new one home squarely.
Posted 10 January 2011 - 12:10 AM
Posted 10 January 2011 - 01:08 AM
http://cgi.ebay.co.u...=item4155d65d59
I picked this similar picks but, I can't seem to get a good hook on it.
Should I hook it on the outside or near the shaft. Isn't it a bad idea to damage the housing? =(
Edited by rocketbeta, 10 January 2011 - 02:41 PM.
Posted 10 January 2011 - 01:11 AM
Check this out:
http://www.theminifo...howtopic=143800
Hope that helps,
Ivan
We both use rocket in our names, which means we are both so cool. Ok, I'm going to resort to the tap and drill as a last ditch effort. My buddy changed out the same seal and somehow he was back to hook it with a small screw driver. Why does mine have to be so difficult. =(
Posted 10 January 2011 - 01:14 AM
Posted 10 January 2011 - 07:50 AM
You will struggle to "pick" or lever the support bush out - really need the gearbox apart and knock it through from the inside. Just refit using a new rubber seal (some people use two seals)
Posted 10 January 2011 - 02:24 PM
Are you trying to get the rubber bit out or the silver bush?
I'm trying to remove the silver bushing. I am struggling to pick the bushing. Take the gearbox apart? That seems like more work. =(
Posted 10 January 2011 - 02:30 PM
Are you sure it has to come out? The quick fix of banging two good new seals in usually fixes any leak...I'm trying to remove the silver bushing. I am struggling to pick the bushing. Take the gearbox apart? That seems like more work. =(
Posted 12 January 2011 - 04:47 AM
Thanks for all the help! I've attached the bushing with the hole I drilled! =)
Edited by rocketbeta, 12 January 2011 - 04:49 AM.
Posted 12 January 2011 - 03:23 PM
So here is what I did. As xrocketengineer indicated to drill a hole and I did but I didn't use a screw instead I just used a small screwdriver to hook it out. It took me about 10 mins to drill and hook.
Thanks for all the help! I've attached the bushing with the hole I drilled! =)photo.JPG 1.34MB 41 downloads
Excellent! I am glad to know that it worked for you too.
Ivan
