My Squeaky Wheel Is Driving Me Up The Wall!
23 replies to this topic
#1 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 07 February 2008 - 09:18 AM
Hey, i was wondering if anyone has any ideas what could be wrong with my mini, there's a squeaking coming from the front drivers side wheel when the wheel is moving. I've had the hub, bearings and ball joints replaced, but its still doing it. Help!!
Sarah
#2 stickycreambun
stickycreambun
  • 1,865 posts
Posted 07 February 2008 - 09:42 AM
Is the CV joint ok?
squeakys are annoying!
#3 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 07 February 2008 - 10:06 AM
I used to have a funny squeak come from the drivers side front wheel, seemed to dissappear when I fitted new front cones. Interestingly the squeak didn't come back when I refitted the original cones.
#4 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 07 February 2008 - 10:48 AM
Is the CV joint ok?
I was wondering if it was the cv joint, but do you need a special tool to get the old one off?
It is getting really annoying! I keep getting worried that when i go round a corner my wheels gonna fall off!
#5 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 07 February 2008 - 12:53 PM
Brake pads i had this on a different car and it was the pads, if you have them? or a brake shoe try adjusting the brakes at the back of teh hub!
#6 Ethel
  • 26,074 posts
Posted 07 February 2008 - 01:02 PM
That's impressive traction :)
Try and decide if it's speed related, if it is look at rotational bits starting with your brakes. If it seems more bump related look at the suspension, pump some grease in; swap your shockers side to side and then work your way through the rubber bushes and mounts.
#7 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 07 February 2008 - 01:13 PM
It is speed related, as the wheel gets faster, the noise get faster, but as soon as you apply the brakes it stops. I was thinking of taking the back plate off, just to check its not that hitting the disk....
She needs new brake disks on the front, but i want to see if I can find what the squeak is, so I can buy bits for that if I need to.
Cheers for everyones help! :)
#8 Ethel
  • 26,074 posts
Posted 07 February 2008 - 01:17 PM
Could be pads or a warped disc, back the pads off and try a short drive without touching the stop pedal - just be wary in case you do need the brakes as the pedal may need pumping to stop.
#9 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 07 February 2008 - 01:19 PM
Ok, thank you!
#10 DaveRob
DaveRob
  • 703 posts
Posted 07 February 2008 - 01:21 PM
You could also try taking the pads out...simple job.... and VERY LIGHTLY smearing some copperslip ON THE METAL BACKPLATE.... not the fricton material lolol....
#11 orangerover
orangerover
  • 38 posts
  • Local Club: north east
Posted 07 February 2008 - 09:10 PM
Is the CV joint ok?
will it go away if you apply the brake?
#12 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 08 February 2008 - 09:12 AM
Is the CV joint ok?
Yeah
#13 I_love_my_mini
I_love_my_mini
  • 117 posts
Posted 08 February 2008 - 11:57 PM
mine squeaks sometimes too though on the passenger side
i find that though this method can be quite complicated its really worth a try
glare at it.
sorry that wasnt helpful at all was it
it doesnt work either very often either
:thumbsup:
#14 VulcanBomber
VulcanBomber
  • 170 posts
Posted 09 February 2008 - 01:23 PM
Is the CV joint ok?
Yeah
It sounds like the pads catching on the disc as the wheels rotate, could also be that pads are getting low on friction material.
Take a look at the pads and get them changed if required.
#15 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 13 February 2008 - 06:55 PM
ITS FIXED!!
Thanks all you lovely people for your help!
Turned out it was the brakes! I took her out today and was braking going down a hill, then she kept doing it really badly, got home to find my new brake discs and pads that Id ordered had arrived, got my bf to fit them (!) and now there is no squeaking! Yay! Now to get my sanity back!! ;) :dontgetit:
