Daughter Zoe's Mini - Yeah Right!
#466
Posted 30 November 2010 - 12:22 AM
'n speak to Roofless about making your very own badge.
#467
Posted 02 December 2010 - 04:49 PM
Literally spent 4 days reading this word for word in my spare time, and I've got to say I think it's the best build thread I've read. Great attention to detail and the colour is beautiful. Top effort all round, very inspiring.
By the way I have a spare airbag for the mpi wheel in storage, with the green Mini badge on it, but I dont think postage would be very safe!
#468
Posted 12 December 2010 - 11:12 AM
Next update heading its way to you. They seem to be getting farther apart now as the car is almost finished. I'm still pottering on a regular basis, just nothing of note to put on an update.
Danny: Thanks for the comments and the offer of the air bag. I wouldn't feel too happy about one going via the postal system either. I took the bag out of the one I have to make it safe for the car. As it stands, I'm not too desperate to change it over.
Ethel: Thanks for the tip on the renovation. I may have a look into this option but as I will need a rear seat to match as well, I may be able to do a deal as a package. Got to get them fitted in first!
After much searching, looking, thinking & suggestions from the TMF, I finally bought a grille.
A wide slat MK1 complete with moustache & whiskers. Wasn't entirely happy with what they cost me, but any used ones I saw were not in the best condition. When I look at the finished result however, worth every penny in my eyes.
Start with the grille
Lamps removed (note in my pals garage where it was drier and just a little warmer)!
Before the grille went on, I needed to fit the points replacement module I had bought.
Very straightforward apart from one of the existing screws not being long enough. As it was an odd thread, we ended up re drilling and tapping to M4, hence the allen head bolt in there.
After fitting & wiring the new coil, (original was ballast) a problem with the running was soon solved with the help of the TMF once again. I searched for a similar problem and found an exact replica of my issue. It was at the bottom of the replies where Ethel said about the timing with the vacuum advance disconnected (Mine was still plugged in),
The car certainlty seems to idle better & run more smoothly now. Can't notice any power difference but the rev counter is now reading stable on the motorway whereas before, it was jumping around all over the place indicating a problem with the points.
On with the grille.............
The grille went on fairly easily. We had to pull it up at one side a little to get it to sit even. Probably more about my front panel than the grille although it is a heritage item. Had to space the horn back as well to clear.
Note: The odd look in the picture I think is due to the light. The grille certainly isn't bent as the picture suggests.
After trimming the top of the lamp brackets, they went back on. Not the easiest of tasks with the grille now in place.
Then came the point which I had been dreading, and one of the reasons the grille had taken so long to be decided upon...
How to get the moustache to fit?
I knew we would have to trim it, just didn't realise quite how much.
After much measuring, marking, cup of tea, measuring again etc, I still wasn't happy about cutting into a brand new, expensive, piece of trim.
No problem there for my pal though who happily set of with the cutters!!!
Moustache on, moustache off, bit more trimming, more measuring, more tea, and eventually..................
The fit is near perfect on the top and also hides the bolts on the lamp brackets.
Very, very pleased.
More marking for the whiskers which were quire easy to fit
And the final finished result
And a couple out in the snow. Posted elsewhere on another topic but what the heck!
Thanks for stopping by
Kind regards
Steve
#469
Posted 12 December 2010 - 12:17 PM
#470
Posted 12 December 2010 - 12:28 PM
#471
Posted 12 December 2010 - 01:17 PM
#472
Posted 12 December 2010 - 07:20 PM
Great job, looks like a finished car now
I wouldn't worry about chopping the tash, if it's a stainless one you can always weld a patch in. Try increasing your plug gaps with the new fangled ignition.
Thanks Ethel, I have opened the gaps to 30 thou as you suggested in the post I referred to.
Regards
Steve
#473
Posted 12 December 2010 - 07:21 PM
Wow looks fantastic! Love the spot light and grille combo. Have you intentionally colour coded it to your vacuum cleaner?
Thanks Peter, glad you like.
I think Mr Dyson may have copied me actually, must have a word!
Regards
Steve
#474
Posted 12 December 2010 - 07:22 PM
Awesome work Steve, love it. Looks spot on
Thanks Chris
Give me a call in the week and we'll get a day back on for your wiring
Regards
Steve
#475
Posted 12 December 2010 - 07:24 PM
#476
Posted 12 December 2010 - 07:25 PM
#477
Posted 12 December 2010 - 07:28 PM
#478
Posted 13 December 2010 - 08:27 AM
Cheers Ross.
#479
Posted 14 December 2010 - 08:34 AM
you should be very proud
#480
Posted 14 December 2010 - 10:05 AM
