have owned it for about 5 years now! It has had a complete rebuild from the ground up about 3 years ago now and has just sat in the garage since with me tinkering with it really. Just adding little bits like 6x12 revo's and other bits and bobs.
I have just turned 18 and after driving the mini round all summer its time to get a bit more speed out of it. I really wanted to get it in the garage a bit later but the real cold weather and the sudden lack of clutch changed my mind and in it went about 2-3 months ago (currently cruising around in a 52 polo 1.9 sdi. umm diesel). I only really started to work on it at the weekend but have done a bit of work already. Just been getting my mini fix buy buying loads of stuff on ebay lol.
My dad worked in a rover dealer for 25+ years before leaving a month before they colapsed and he owned 2 minis when he was younger writing of one of them which happened to be a 850 woody!!! then borrowing his brothers and send that to heaven to.
My dad seems to have an obbsession with 998's and believes they were the far superior engine. So i am sticking with it for a while.
i just want more power!!!!!!!!!
So i am going to try and squeeze some more juice out of this badboy engine. It currently has a few mods fitted to it. A big bore exhaust system with a boxter back box which probably reduces power but my old exhaust was a state and my brother had bought this exhaust for his clubman estate (which sadly hasnt taken of the ground and is rusting away if anyone is interested??) so thats what i got for it as it was free. It also has some ofset rockers on it whick came from an old cooper (the cast type) the best ones ive heard. Thats about it power wise.
I have also aquired the following parts just from my dad having them around and him buying them on ebay a while back:
two heads a 12G202 and a 12G940 the 202 i might get changed to unleaded but the 940 is of a 1300 so am a bit unsure for power and fitting on this? if anyone can help?
Two sets of twin SU's which i probably wont use as there aint no need on a 998.
Lots of other bits and bobs lying around i just need to sift through them.
Now on to the project so far and what i want to do to it.
Help would be appreiciated as my dad is an expert on engines and does know how to make them go faster but i always like a second opinion on things and im sure he doesnt have that much experience with the numerous part numbers and tunning companies.
Well first of is to fix the problems i have got.
I have tracked down the clutch problem to be the master cylinder so i have one of them on order.
The carburettor is absolutly shocking everything is coming loose on it, you set it up all nice give it a good rev and it goes back to being really rich again there is alot of things that need to be changed on it so...
I am going to try and get my hands on a HIF38 as i have heard from reading around that this would be my best option rather than have twin carbs or a webber/s (for 998).
What i want to get:
A new camshaft from swiftune unless there is a better one??????
Any other good value tunning i can do whilst im down there lol?? help apreciated.
(Am i allowed to ask questions like this still a bit confused with it didnt want to clutter up the other section with little questions?)
Get a new head for it with big valves and port polishing. Or sort one of the other heads i have.
A new exhaust system to boost power.
Possibly new pistons.
And just a general overhaul of the electronic side like new spark plugs, coil, ignition etc.
