Overheating!!
Posted 02 August 2005 - 09:44 PM
The fan is working (it spins anyway), and there's nothing on the grille obstructing the cold air intake, so what could it be?
Any help appreciated. Cheers. Guido.
Posted 02 August 2005 - 09:50 PM
Posted 03 August 2005 - 07:17 AM
Posted 03 August 2005 - 09:31 AM
chocolate jazz
Posted 03 August 2005 - 10:03 AM
Posted 03 August 2005 - 10:27 AM
Posted 03 August 2005 - 10:48 AM
However, I sorted everything mentioned so far in this thread no sender/thermo/voltage faults and my 1380 was still overheating. A trip to the rollers sorted everyithing out.
Posted 03 August 2005 - 01:29 PM
Posted 03 August 2005 - 02:53 PM
Posted 03 August 2005 - 05:07 PM
I'm gonna go out now and check everything that was mentioned here.
Cheers. Guido.
Posted 05 August 2005 - 11:50 AM
check all the obvious stuff like do a rad flush, airlocks,water pump, themostat, fuelling etc, then get a new 4 core rad.
if that doesn't work then your head gasket could be going - I had no mayo or bubbles in the rad but gas was escaping the cylinders and pressurising the water jacket enough just to boil the coolant. put a new gasket on - cured over heating
Posted 05 August 2005 - 12:56 PM
Posted 05 August 2005 - 01:18 PM
Yeah, i suspected this may be the case too, until I drove for 20 mins this morning, when I got home smoke was POURING out from the engine!!How hot does the engine and rad FEEL after a journey. My gauge reads nearly max after only a few mins but even after a 10 - 15 minute journey I can remove the rad cap with no pressure hiss or anything, dipped the water with a meat thermometer and read only 75 ish. So whilst the gauge is saying you had better stop, everything else seems to be ok. Am going to chage sender unit at weekend to see if that changes anything, will let you know.
I've had no mayo either, but I may replace the h gasket too to see if it does the trick!
Cheers!
Posted 05 August 2005 - 09:54 PM
Posted 06 August 2005 - 09:04 AM
As i once learnt in my old chevette, going along the M40, "cool, the gauge is reading cold, the overheating problem has disappeared!". Along with it all my coolant. I was young and foolish. Carried on for a couple of miles tho!! Ended up replacing the engine in a cinema car park in high wycombe a few days later...If there's no water the temperature gauge reads cold, since it's measuring the temperature of the coolant.
