Crank Position Sensor?
Posted 14 July 2009 - 05:01 PM
I have a problem where my rev counter needle dances up and down for a few seconds, when this happens the engine stutters. I think it must be the crank position sensor but before I shell out £80 I thought I'd check on here to see what you people think. It idles fine and can go for miles without the fault occurring but when it does the engine almost dies. Anyone with a diagnostic sensor near Salisbury?
Many thanks for your help.
Rover Mini Cooper Spi '94, 89000 miles
Posted 14 July 2009 - 05:04 PM
Posted 14 July 2009 - 05:12 PM
Posted 14 July 2009 - 07:03 PM
Yeh whenever the needle does a dance it looses power. The crank position sensor looks pretty easy to change, just want to make sure it isn't something else.
My money is on the coil!
Posted 14 July 2009 - 08:25 PM
Ideal, connections? whole thing busted? What should I look for?
Posted 14 July 2009 - 08:29 PM
Edited by Rosslin Racing, 15 July 2009 - 07:49 AM.
Posted 15 July 2009 - 12:38 PM
could be conection look at them good clean them if oily and clean the coil as well. see if that helps if not change the coil for one you know that works if no joy then the sensor may well be duff
Had the same problem recently on my '95 Spi cooper - turned out to be the crank sensor connections were corroded. Gave them a good clean up (both in the plug and the socket - you can unbolt the one attached to the engine for better access) cleaned them up with fine sandpaper. Sorted.
My car actually went from running, to not starting at all (for a day) to starting and running but spluttering everywhere, then when I came home with a meter, scope etc from work, seemed to be fine (typical). then later that day it happenned again - so while it was doing it, I waggled the connector for the crank sensor and it stopped doing it - good sign!
Also, if it is the crank sensor signal dropping out, then each time it happens the fuel pump and main relay in the black relay box, will switch off . So you could put your ear to the box and listen for the clicking of relays which are going on and off as a further clue. On mine, I can remove the cover of the relay module due to a previous repair, so I can see the relays operating.
But easiest check, waggle the crank sensor connector when its happening.
Posted 15 July 2009 - 08:57 PM
Posted 15 July 2009 - 09:21 PM
Ah that makes sense, I wiggled the connector and it drove really well for ~100 miles then started playing up again. I'll have a look tomorrow evening and clean up the connections. Cheers!
Hope it turns out well. Let us know the outcome.
Craig
Posted 17 July 2009 - 08:28 PM
Posted 18 July 2009 - 07:39 AM
Keep us updated
Rob
Posted 18 July 2009 - 07:00 PM
Cheers Rob.
Posted 20 July 2009 - 06:09 PM
Posted 23 July 2009 - 07:23 PM
Cheers.
Posted 07 August 2009 - 09:03 PM
