Quick Question On Tach Wiring.
15 replies to this topic
#1 mwalsh
mwalsh
  • 119 posts
Posted 18 October 2009 - 07:47 PM
On the 125GT style tach....which of the two terminals goes to the negative side of the coil, the spade or the bullet? And the other goes to ground, correct?
#2 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 18 October 2009 - 11:31 PM
If nobody here knows the answer, then try these: -
Click Me
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 18 October 2009 - 11:41 PM
Mike, I'm not familiar with the specific gauges in a 1275GT. However, the common practice for Smiths was to run power in on an insulated spade lug. Metal gauge cases may also have a spade lug for the earth connection. The coil connection method depends on the tach type. RVI tachs use two bullet connectors in series with coil power. RVC tachs use a single bullet connector connected to the coil (-) terminal.
#4 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 18 October 2009 - 11:45 PM
The 1275GT came with a triple instrument pack that incorporated the rev counter and it had a printed circuit on the rear.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 October 2009 - 12:33 AM
If this is the tacho fitted as part of the multi instrument pack then the earth terminal is a screw in the case because it was provided through the PCB. The terminals are for power and signal. Instrument lighting is also provided through the PCB.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 19 October 2009 - 12:56 AM
No disagreement from me. As I said, I'm not familiar with the instrument package on a GT. However, Mike did ask about spade and bullet connectors... which implies in his particular case/car, he is not dealing with a PCB.
#7 GraemeC
GraemeC
  • 7,446 posts
Posted 19 October 2009 - 08:18 AM
However the 1275GT came with both RVC and RVI type tachs in the multi-instrument pod, dependant on age.
Post up a picture of the rear of the tach and we'll be able to tell which one you have and how to wire it correctly.
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 October 2009 - 11:24 AM
What the late clocks have is a post and a spade for connecting the power and signal, with a thin PCB laid over the back to supply earth and lighting. This is because power and signal for the tacho aren't included in the clock multi connector while earth and lighting are. It's a silly system. People quite often seem to pickup the tacho as a seperate instrument because it is in its own casing simply screwed to the end of the main case. They assume that since it is in a case by itself it works independantly of the main unit but it doesn't.
As Graeme says though, if it is a 1275GT tacho (and not someone simply saying it's 1275GT because that's where they were first used) then it could be the older type. In which case it will obviously have different connections.
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 19 October 2009 - 12:07 PM
Thanks for that Dan. Hopefully Mike will post a picture which should make it even clearer.
#10 mwalsh
mwalsh
  • 119 posts
Posted 19 October 2009 - 01:38 PM
I was saying 1275GT because that's where I remember them first being used. You rumbled me. :thumbsup:
That said, I do have both RVC and RVI examples. I was trying RVC yesterday and, since I don't know condition of the RVI I know I have on hand, probably getting the skinny on the RVC would be best.
What I'm looking for is simplified wiring instuctions so I can hook one up to a loose motor.
So what I have is the motor sitting on a cart, with the battery on the floor. It's already been running, so I'm fairly confident that what I've hooked up so far is correct. I just need to be able to add the tach in so I can properly set the timing.
Picture below is earlier in the day, before I got the dizzy in, the carb and manifolds on, and my temporary wiring loom hooked up.
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 19 October 2009 - 03:32 PM
Graeme said there are both RVC and RVI cluster mounted tachs for the GT. Dan described the back side of the typical cluster gauges.
Hopefully that will describe things well enough. I think you'll find where bullet connectors are used, they are for the coil connections while spades are used for power. If you've got a picture of the back of the gauge you'd like to use I'm sure it will be easily sorted.
by the way, the RVC tach will be much easier to work with.
#12 mwalsh
mwalsh
  • 119 posts
Posted 19 October 2009 - 04:16 PM
Ack! I didn't take a picture. I figured once I said I had RVC you guys would know without.
So, OK, RVC with a post, spade, and a screw for earth. Which between the post and the spade is for power and which goes to the negative side of the coil?
Edit: Oh, sorry Doug, I didn't see where you said which is which. So bullet for coil and spade for power. We're 100% on that, yes?
Further edit: Linkie for if you want to watch me YouTube vid of the startup. Not really the first startup though, had a few goes before everything was dialed in as close as I could without a tach:
Video
Edited by mwalsh, 19 October 2009 - 04:25 PM.
#13 GraemeC
GraemeC
  • 7,446 posts
Posted 19 October 2009 - 04:37 PM
RVI 1275GT Tacho
Male spade connector - 12V IGN Source (white wire)
Small Screw below spade connector - Earth (usually via screw into PCB)
Female bullet socket (next to screw) - Connection to coil +ve (white/green wire)
Male bullet (above female) - 12V IGN Source (white wire)
RVC 1275GT Tacho
Small screw nearest male bullet connector (top right in photo) - Earth (usually via screw into PCB)
Male bullet - Connection to coil -ve terminal (usually white/black wire)
For future reference - ignore the wire colour shown in the photo above as it is incorrect!!!!
Edited by GraemeC, 19 October 2009 - 05:33 PM.
#14 mwalsh
mwalsh
  • 119 posts
Posted 19 October 2009 - 04:52 PM
RVC 1275GT Tacho
Cheers guys! Just what I needed.
#15 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 19 October 2009 - 07:10 PM
Thanks Graeme. That clears things up for me quite a bit as well.
