Single Speed To Twin Speed Heater
Posted 14 January 2010 - 09:18 PM
i have a single speed plastic heater and id like to have a twin speed function like the mpi.
ive heard that the single speed heater are the same as the mpi type except the mpi ones have a resistor pack to make it twin speed.
so my question is.
how would i got about making a resistor pack to convert my single speed heater to twin speed heater?
if some body could measure the resistance across the slow speed on thier mpi heater for me that would be most helpful.
cheers everyone
Posted 14 January 2010 - 09:22 PM
Posted 14 January 2010 - 09:43 PM
how have you wired the resistor in?
i was thinking of having 12 to the common of the switch,
one pole straight to the motor (full speed)
and the other pole through the resistor, then to the motor (half speed)
would that work?
does the large resistor put alot of strain on the cars wiring?
Posted 14 January 2010 - 09:48 PM
the resistors will not put extra strain on the wiring, they will actually reduce the strain.
Posted 14 January 2010 - 09:54 PM
what resistor should i use as all the 1.8 ohm ones i can find are the normal small type?
Posted 14 January 2010 - 10:27 PM
They are probably over kill, but ain't that expensive. The 2R2 or 2.2 Ohm resistors should be fine. A motor only has a low resistance anyway so therefore you only need to use a low resistance to make the motor speed different.
If you want i can draw you a little diagram on how to wire these.
Posted 14 January 2010 - 10:35 PM
Posted 14 January 2010 - 10:38 PM
the size is related to the power handling of the resistor
IIRC a heater motor consumes about 2 amps,
12v x 2 amps = 24 watts
24 watts / 2 squared = a heater motor restistance of 6 ohms., so adding about 2 ohs to that should give a significant drop in speed.
so assuming 6 ohms for the heater motor + 2 for the resistor = 8 ohms...
12v / 8 ohms = 1.5 v per ohm so there will be 3v across a 2 ohm resistor,
3v/ 2 ohm = 1.5 amps..
1.5amps squared x 2 ohms = 4.5 watts disipated in the resistor,
So I recomend a 5watt 2 ohm resistor. you can increase the resistance (say 2.2 ohm) without needing a higher wattage resistor, but if you go lower you may need to go larger.
if you want to check the sums....
http://www.the12volt.com/ohm/page2.asp
Or be really flash http://cgi.ebay.co.u...=item27ae824596
that does look cool but id like to keep it looking like a mini heater. two speed is enough for me lol
Posted 14 January 2010 - 10:51 PM
so if i get this one http://cgi.ebay.co.u...=item20aef522a9
is it ok if the wattage is 50watts rather that the 5w that you recommended?
Posted 14 January 2010 - 10:53 PM
Posted 15 January 2010 - 09:20 AM
and would this work ok just connect the fan up to it and away i go?
thanks people
Posted 15 January 2010 - 03:54 PM
with regards to wiring a resistor could someone please put a wiring diagram on here or send me a Pm thanks.
thanks people
all you would need to do for this is it put the feed (after the switch) in one connector. and the connections to the motor in the other
