Nut Size On Door Hinge
7 replies to this topic
#1 battleroc
battleroc
  • 135 posts
Posted 14 February 2010 - 09:38 PM
Hey guys
Ive got a 1995 cooper spi that ive been restoring and i have the doors in place, but the nuts that go on door hinge thread.... which you reach under each arch the nut heads have worn out big time so i want to replace all 8
anyone know what size these nuts are.... i am sure they are unf but not sure on size?
i am going to try order some nuts if i can online once i know the size, anyone know
and also anyone know where i can get them online?
cheers
Dan
#2 jameswhiles
jameswhiles
  • 309 posts
  • Local Club: A5 Minis
Posted 14 February 2010 - 09:40 PM
If they are UNF they will be 7/16 but if they are worn out that badly use an impact socket. 10 or 11 mm should work depending on how bad they are. Be sure to soak them with wd40 first!
#3 battleroc
battleroc
  • 135 posts
Posted 14 February 2010 - 09:43 PM
cheers feller.....would you recommend nylon lock nut or just normal thread 7/16 unf
#4 mars red mike
mars red mike
  • 1,500 posts
Posted 14 February 2010 - 09:49 PM
I use Nyloc nuts and a good coating of copper grease once fitted.
#5 samsfern
samsfern
  • 5,243 posts
not 716 thats massive, i think you mean 7 16 head, the thread size is 1/4" unf. Personally i dont like nylocks, id use some fairly big washers, to spread the load, and some spring washers.
#6 jameswhiles
jameswhiles
  • 309 posts
Posted 14 February 2010 - 09:56 PM
Yea thats what I meant sorry! a 7 16 spanner :)
#7 battleroc
battleroc
  • 135 posts
Posted 14 February 2010 - 09:58 PM
http://cgi.ebay.co.u...=item5ad70a8cd3
l think these will do the job :)
#8 Ethel
  • 26,074 posts
Posted 15 February 2010 - 12:00 AM
Much cheaper from Minispares
gfk3321 12p each
