Thought I would tell you what I am doing, I am in the 1st stages of converting my 1.3i to a turbo carb engine
Thought I would start this thread up, as I have now collected 90% of the parts I need and the rest will only be brought after I fit the 1st lot so I know space left in the engine bay
It will be running it at low boost as I am at 1st keeping the spi's internals. Here are the main things I will be changing over:
Metro turbo head
Adding a adjustable boost valve
Turbo hiff 44/ inlet manifold/plenum/ dump valve
Mega jolt/edis set up
Custom exhaust manifold set up
Spanking new Garrett Gt-1548 turbo (mounting this on clutch housing like a janspeed set up)
Here is a pick of the car so you can see it as it is ……..engine pictures to follow
