before it eats him up, and sort out a few mechanical faults. Let's start with something simple
Saved a few quid thanks to R1minimagic (cheers, Dale). The previous garage had wrecked
most of the wheelnuts by using the wrong socket apparently fixed to a rocket launcher.
Now a few donor items from Huey (thanks, mate). At least one new tyre, plus standby brake discs, calipers and
pads, all almost new. So they'll be used as and when.
Rocky has been checked out at "our" garage and we have drawn up a list.
First jobs:
*New top engine steady bush DONE
*New front wheel bearings DONE
*New front shocks (rear were replaced late last year) DONE
*2 almost-new Yokos from Huey DONE
*Renew brake fluid & bleed brakes DONE
*Strip out seats, carpets & underlay to get a proper verdict on the floor & arches. Weld up as necessary (pix below) DONE
*Weld patch over hole in o/s sill DONE
*Weld rear subframe mounts & fit new subframe, applying Stoneguard & waxoyl before & after DONE
*Waxoyl all other areas not conflicting with body repairs next week DONE
*Weld up crack in front end of exhaust DONE
*Put seats back so Rocky can go to the body shop DONE
*Go for a nice sunny drive with Mrs T brrrm brrrm DONE
Next job, in body shop:
*Deal with rust (pix below) DONE
*Test for water leaks ... it'll rain soon so we'll do it then.
EDIT Well it's rained for 2 days and he seems dry enough DONE
*Meanwhile, at home, clean carpet and interior DONE
Next jobs, in garage:
*Complete waxoyling DONE
*Disconnect airbag & seatbelt pre-tensioner circuits. Replace all seatbelts with nice red mechanical-tensioner ones DONE
*Fit ciggy lighter socket for satnav DONE
*Get interior light to work properly STILL FIDDLING
*Fix malfunctioning cassette/radio unit, or replace it STILL FIDDLING
*flush out coolant & refill with correct anti-freeze DONE
*Replace underlay, carpet & seats & finish cleaning interior DONE
Next job: out with the t-cut and wax and on with that deep, deep shine in time for glorious summer.
Well, that's the plan, anyway.
Edited by Teapot, 23 March 2010 - 07:30 PM.
