Mot Question Regarding Rear Fog Light
Posted 02 March 2010 - 09:30 PM
I have just fitted a new rear valance and i have fitted a flush fitting rear fog http://www.cbsonline...fl5s-4136-p.asp into the valance in the centre.Then i stood back to have a look and had a brain wave as to wether it would be aceptable for the Mot man.Anyone know?
Thanks Pete
Posted 02 March 2010 - 09:52 PM
I have found this info for you from this web site. http://www.motuk.co.uk/manual_110.htm
The inspection of rear fog lamps is confined to the one rear fog lamp which is required to be fitted to the centre or offside of
vehicles first used on or after 1 April 1980.
Note: On some vehicles the front fog lamps need to be switched on before the rear fog lamp(s) will work
Note: A rear fog lamp is permitted to operate independently of headlamp, position lamp or ignition systems.
Note: at least 50% of light sources in a lamp must illuminate
6. With dipped headlamps and the ignition switched on, operate the rear fog lamp switch and check that a rear fog lamp
. is fitted to the centre or offside of the vehicle
. is working, and
. does not flicker when tapped lightly by hand.
Check also that the drivers tell-tale works properly.
7. Check the presence, condition, security and operation of the switch.
6. A mandatory rear fog lamp
a. is missing, does not emit a steady red light or emits a light other than red
b. incomplete, not in good working order or not visible from a reasonable distance
c. is insecure, obscured or not facing to
the rear
d. flickers when tapped lightly by hand e. tell-tale does not work
f. adversely affected by the operation of
any other lamp.
7. A rear fog lamp switch
a. missing
b. faulty
c. insecure
d. not able to be operated from the normal driving position.
I think this covers what you need.
Posted 02 March 2010 - 09:57 PM
and Shaddy (on hear) had his on the mini in the center on the parcel shelf went through 2 mot's i think before it went to that scrap yard in the sky
Posted 02 March 2010 - 10:00 PM
Thanks for the replys
Pete
Posted 02 March 2010 - 10:10 PM
I think it has to be at least 25cm from the ground and it has to be a certain distance from the brake light.
The information is on the forum some where.
Posted 02 March 2010 - 10:24 PM
Though ones that are in the middle are actually a couple of mm to the right, so you can get away with it.
MX5 city used to fit the fog lights to jap imports, a couple of mm off the centre line.
Posted 02 March 2010 - 10:29 PM
So it must be ok
Posted 03 March 2010 - 07:57 AM
Posted 03 March 2010 - 08:03 AM
Details are in the FAQ's
http://www.theminifo...?showtopic=6445
unfortunately it's so old the picture has gone !!!
Posted 03 March 2010 - 08:31 AM
Hi
Thanks Pete
Can we have some pictures please?! I was planning on doing exactly the same thing ( have even got the same lamp unit) although mine will be offside due to my centre exit exhaust.
I think the best way to check is to sit your Mini on a road. Walk back the distance a car would be following you at and see if you can see the lamp. I'm sure you'll be fine as long as it's not tucked up tight under the bumper.
Posted 03 March 2010 - 03:39 PM
Posted 03 March 2010 - 08:03 PM
Cooperman did think about mounting in the boot lid but its new and i darnt attack it with the angle grinder.
Pete
Posted 08 March 2010 - 01:03 PM
This means its 100mm away so would this solve the problems? would it not?
Not sure of legality?
so brake
indicator
then fog
Just an idea.
Posted 08 March 2010 - 07:47 PM
Posted 08 March 2010 - 08:13 PM
Is that just screwed straight to the valance then? Does it point down at the ground?
