1975 mini city 998
clutch problems
hi
i am going to be fixing my friends clutch on his 1975 mini city 998. the problems we have with it is that you have to pump the pedal for the clutch to disengage. once you have pumped it a few times its ok for a while and then you need to pump it again. i had a look at the fluid in the master cylinder and it looks all murky and dark brown.
i cant see anything fluid leaking from the slave cylinder so is this just a case of me replacing the fluid and giving it a bleed?
also do i replace it with dot4?
cheers
Sorting The Clutch On A 1975 Mini City
davexdavexdave
, Mar 08 2010 12:35 PM
4 replies to this topic
Posted 08 March 2010 - 12:35 PM
Posted 08 March 2010 - 12:57 PM
Replacing fluid and bleeding is a good starting point. If that doesn't work it could be either the slave (easy) or master cylinder (not so easy) that need replaced.
Posted 08 March 2010 - 01:09 PM
ok mate ill bleed it and go from there then
cheers
cheers
Posted 08 March 2010 - 10:36 PM
It can't be a Mini City though, that wasn't launched until 1979.
Posted 09 March 2010 - 11:38 AM
maybe its not i just thought i saw city in it. its my friends car so im not 100% on what it is
