oil smoke out of exhaust
Posted 05 November 2005 - 06:41 PM
ive got a 2,500 mile old engine, i ran it in properly for 1000 miles, then changed the oil for good stuff and new plugs etc
its been constantly chucking (alot) of smoke out the back, whenever i leave from a standstill at the traffic lights
it only does it when the accelerator is depressed a very minor amount, say to get the engine to rev to perhaps 1200rpm for a slow move off from stand still, but it is quite an alarmingly large amount of smoke, its white smoke, but definatley oil. oil doesnt have to be a bluey colour.
now, when i decked my head to the block, the machine shop didnt quite get a perfect finish on the mateing surface on the head, and i had my engine builder smooth it off himself, if this wasnt done quite properly would this allow oil from the galleries to seap into the combustion chamber and cause the problem?
kinda asking on behalf of Flappyplasticbits too, as his had the same problem
those who were on the nurburgring run will know what im on about, especially minis84 and mentalist who had to put up with a smoke machine in front of them
Posted 05 November 2005 - 06:48 PM
Posted 05 November 2005 - 07:03 PM
Posted 05 November 2005 - 07:51 PM
Posted 05 November 2005 - 07:55 PM
Posted 05 November 2005 - 08:29 PM
I hope it's not that in your case though as that is a very young engine and it would be awful to rip it apart again.
Posted 05 November 2005 - 08:34 PM
Posted 06 November 2005 - 01:05 PM
Posted 06 November 2005 - 03:51 PM
Unfortunately I needed the car to drive to work and so I was unable to dismantle the engine so I decided that I was going to have to drive the car for a few months and then when I next got some time I would examine the head and block. After about 2500miles it magically stopped smoking and now it runs perfectly.
I would advise that you drive the car for a few more miles and see if it stops; if it does then you wont have the hassle or expense of stripping down and rebuilding the engine again.
I don’t think that the oil burning can cause any major damage only to the wallet for the extra oil needed.
Posted 06 November 2005 - 05:28 PM
dave
Posted 07 November 2005 - 12:10 AM
not going to let it get out of hand though, i know what damage i could do
Posted 07 November 2005 - 07:29 AM
dave
Posted 07 November 2005 - 05:03 PM
The little rubber seals on the valve stems are not what ususally causes valve oil leaks, as most of the oil is excluded by the tight fit of the stem into the guide. Once the guide is worn there is little you can do to prevent oil leaking through even with new rubber seals. Oil leaks through the stems will normally be revealed as a cloud of smoke on startup rather than while running, as there is relatively little oil collecting on the tops of the valves while running and it woud be drawn through slowly and continuously leaving a fine mist behind the car rather than a big cloud of fog. When the car is sitting overnight however a relatively large amount of oil can trickle down the stems and pool in the inlet port to then be drawn in and burnt when the engine is started.
Edited by Dan, 07 November 2005 - 05:04 PM.
Posted 07 November 2005 - 07:27 PM
