cheers all
Sportspack Arches Bolt Question
miniallsort
, Jul 26 2010 05:52 PM
2 replies to this topic
Posted 26 July 2010 - 05:52 PM
hi quys what nut and bolt size did you use to put your sportspack arches on ?
cheers all
cheers all
Posted 26 July 2010 - 10:25 PM
I had to refit my original sportspack arches after a respray. Several of the original studs were knackered... I cut the heads of some M5 bolts and expoxied them into the arches. Worked a treat.
If you have original arches then I think the the studs are available once agian from Somerford Mini (STUD001... the nut being FN105041, and RY612535 being the large head pop rivit for the ends).
See them at... http://www.somerfordmini.co.uk/eshop/index.php?main_page=page&id=29
If you have aftermarket arches (e.g. fibreglass) then maybe others can answer your question better... but I'd suppect a 3/8" or 1/2" selftapper and a little epoxy might be a decent solution.
Cheers,
Colin.
Cheers,
Colin.
Posted 27 July 2010 - 10:04 AM
thanks very much colin:)
