Would Standard Arches Cover This?
5 replies to this topic
#1 Lukie-J
Lukie-J
  • 858 posts
  • Local Club: South Devon Mini Club
Posted 31 July 2010 - 01:52 PM
My arches have been fitted and re-fitted and repaired so many times that it is with regret that I'm going to have to get some others.
Would standard wheel arches cover this?
Also, the front wing has been trimmed, would I still be able to fit them properly?
#2 project mini chris
project mini chris
    have a break, have a...
  • 1,894 posts
Posted 31 July 2010 - 02:00 PM
have you measured how far the wheels stick out? if you have and know the measurement then you will know for sure, if i remember right standard wheel arches give a coverage of about 1 1/2 inchs?
#3 ministar
ministar
  • 835 posts
Posted 31 July 2010 - 04:14 PM
My guess they are 4.5'' wide with discs at the Front, spaced drums at the back. Both with no additional spacers? If in that case yes they will fit. A little more info would be better :)
- If they are 5'' it may be tight! When my new wheels (5'') went on with the standard arches they stuck out about 10mm. however group 2 narrows are fine and cover them.
Edited by ministar, 31 July 2010 - 04:19 PM.
#4 pikey7
pikey7
  • 3,824 posts
Posted 31 July 2010 - 04:51 PM
doubt standard arches would cover enough. Looks about an inch too much.
#5 Asphalt
Asphalt
  • 2,173 posts
Posted 31 July 2010 - 06:05 PM
1.75" :P
#6 project mini chris
project mini chris
  • 1,894 posts
Posted 31 July 2010 - 07:24 PM
1.75" :P
your a legend, ta :trooper:
