Clutch Bleeding Issue
5 replies to this topic
#1 racerlike
racerlike
  • 443 posts
Posted 04 September 2010 - 09:17 PM
Started to bleed the clutch today using my original master cylinder, new slave and new hose.
Pedal depresses freely but the fluid is not being pushed into the hose.
I was pushing the pedal up and down for ages but the fluid wont budge - could my master cylinder be at fault here or does it just take a long time to build pressure up? it hasnt been in use for a couple of years now.
thought id check here first before going and buying a new one
#2 Ethel
  • 26,580 posts
Posted 04 September 2010 - 09:54 PM
I'd say there's a fair chance the seals have gone if it's been sat. It's not much more complicated than a syringe, push on the pedal and fluid should come out.
To test it, push the pedal to the floor then block off the outlet (a crimped over bit of pipe in a union is ideal). Then let the pedal return and give it another push - it should be rock solid.
#3 racerlike
racerlike
  • 443 posts
Posted 08 September 2010 - 08:51 PM
cheers
yeh i gave that go - its definately not working. So i got myself a master cylinder repair kit, fingers crossed that should do the trick
#4 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 08 September 2010 - 08:53 PM
did u have the lid off the master cylinder?
#5 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 08 September 2010 - 08:58 PM
i had problems bleeding mine, with the bleed nipple open, put your finger over the hole and then get someone to pump the pedal, the pressure builds up enough to get the fluid going through, but lets enough air out to allow the fluid to flow through, worked a treat on mine, when the fluid starts to come out, bleed as usual
#6 GreenMini17
GreenMini17
    Formally known as Chris-G
  • 424 posts
Posted 09 September 2010 - 09:22 AM
Is the bleed nipple open enough?
