I''m trying to remove my side indicator repeators and replace them with clear ones, however the haynes manual doesn't tell you how to remove them, it just tells you how to change the bulb which doesnt suprise me as it's such a small thing.
Does it just pop out? I have a feeling it does, but didn't want to force it and damage my wong or something.
Thanks in advance.
How To Remove Side Indicator's.
scotty_18
, Sep 05 2010 05:14 PM
6 replies to this topic
Posted 05 September 2010 - 05:14 PM
Posted 05 September 2010 - 05:32 PM
My ones have a tab each side the you push together, you put you hand up the inside of the arch and just squeeze together, it then just pushes out.
Posted 05 September 2010 - 06:58 PM
on my spi - Push hard to the left ( or maybe right - iv just double doubted myself) - and then they fall out.
Posted 05 September 2010 - 09:37 PM
cheers guys. got them out, however im now having trouble putting in the new ones, they're so hard! might use a tad of sand paper to make it an easier fit because im that frustrated by trying so much.!!
Posted 06 September 2010 - 05:53 PM
Anyone know a good way of how to get them back in? frustrating me BIG TIME!
Posted 06 September 2010 - 11:26 PM
Ive just put some new ones in my mini as was having the same troubles. I ended up cutting a bit of the plastic on the tab off with a stanley knife, so the back would squeeze in more, took a lot of pushing but got them in in the end!
Posted 07 September 2010 - 11:16 AM
well my idea was to sand down the side that wont go in properly ever so slightly, put some vaseline on it and give it a go
