Air Conditioning
Posted 07 September 2010 - 10:39 AM
97 mpi power plant
AC?
hi, i may be taking the hornet somewhere really hot, and am wondering about ac. I understand that some export models had ac, but i cant find any data on it, nor any parts. I have installed ac before, so any parts/data is totaly welcome. thanks
richard
Posted 07 September 2010 - 10:49 AM
As far as I know, the post-96 distributorless engines that came with the AC is the Japanese spec engines, HOWEVER they are SPi but with distributorless ignition system and also with a side-mounted radiator.
Is your Hornet retains the side rad or the MPi front-rad? I don't know whether the MPi setup (with the front-mounted rad) will be able to run a Japanese spec AC system or not due to lack of space...
Posted 07 September 2010 - 10:53 AM
This is a tricky one.
thanks, i have the front mounted rad, im running full MPI, there is a big hole where the side mounted one sat. I heard that the condenser sat in the front of the front mount, and it must be frickin tiny!
Posted 07 September 2010 - 11:00 AM
Check out Car Builder Solutions http://www.cbsonline...lation-91-c.asp
They have air con systems, although expensive that should be posible to retro fit to a Mini.
Posted 07 September 2010 - 12:23 PM
There are always other methods available.
http://www.cbsonline...ircon-294-p.asp
wow! nice, still need a comp and condenser though
Posted 07 September 2010 - 12:31 PM
Posted 08 September 2010 - 11:53 AM
thanks for that! I did a search first, but didn't find that linkIf you want to make your own aircon system, you could probably check THIS THREAD for some ideas...
