Starter Solenoid
Posted 07 September 2010 - 05:38 PM
Posted 07 September 2010 - 06:07 PM
a pic of mine before the strip out
the pic is front of car to the right and battery goes to the top terminal as you lok at it, I think !!!
Hope it helps,
Graham
Posted 07 September 2010 - 06:10 PM
battery terminal and all the brown wires on one threaded terminal, starter motor cable alone on the other.
Posted 07 September 2010 - 06:18 PM
Posted 07 September 2010 - 06:47 PM
Anyway
I tried a battery feed on both threaded terminals and only time the ballast byepass terminal goes live is when the solenoid is energised.
So on that test it doesn't matter which terminals you use as long as the starter cable is always on its own terminal with nothing else attached
Although saying that most solenoids come with one of the terminals with a large spade connector on the threaded terminal, that is the battery and brown wire terminal
Edited by lrostoke, 07 September 2010 - 06:49 PM.
Posted 07 September 2010 - 06:57 PM
Just incase I'd given duff info I have a spare solenoid in the garage so just been and tested it
yes sad I know
Anyway
is it my turn to rush out and test one now.
Be wary as some solenoids definitely behave the way i said, as i diagnosed a dead coil recently for someone and the fault was the solenoid connected the wrong way round causing exactly the point made above.
Not being funny, and maybe the solenoid was faulty too, but it cured the issue with the coil.
just dont want to see a Mini getting hurt is all. not trying to contradict anyone. I shall go away now.
Posted 07 September 2010 - 07:03 PM
Could be some out there that are terminal specific, which is why I ended with the use the big spade connector as a guide
Can see big spade terminal in this pic
Posted 07 September 2010 - 07:07 PM
Posted 07 September 2010 - 09:17 PM
Knew I could get the answer on here. Such a wealth of knowledge!
