Speedo Drive
Posted 08 September 2010 - 04:09 PM
Posted 08 September 2010 - 04:13 PM
Posted 08 September 2010 - 04:50 PM
Posted 08 September 2010 - 04:53 PM
Posted 08 September 2010 - 05:01 PM
Posted 08 September 2010 - 05:02 PM
Posted 08 September 2010 - 05:06 PM
ive got same problem but what drill bit do you use to see if the speedo clocks work as mine speedo cable does twist ???
Just put the cable end (gearbox end
Posted 08 September 2010 - 05:08 PM
ohh thats the thing when i plug my speedo in nufin happens but the cable still twistive got same problem but what drill bit do you use to see if the speedo clocks work as mine speedo cable does twist ???
Just put the cable end (gearbox end) in the drill chuck and tighten it hand tight, let the drill turn slowly if using an electric drill ....i used a hand drill
Posted 08 September 2010 - 05:11 PM
Posted 08 September 2010 - 05:21 PM
ya lol i will have a look see if i can stick anythink in the speedo so i can spin itSounds like you have the same problem as me but in reverse LOL
Posted 08 September 2010 - 05:50 PM
Posted 08 September 2010 - 05:52 PM
yh ive checked the end looked fine but saying that i havent seen the end of of any other speddo cable lolHave you checked the end of the cable...may have worn and just spinning in the speedo and not turning the drive?
Posted 08 September 2010 - 06:25 PM
Posted 09 September 2010 - 04:49 PM
