Auto To Manual
Posted 08 September 2010 - 05:31 PM
Posted 08 September 2010 - 07:10 PM
Take a look at this topic here. Somewhere within the replies there is a link to a load of PDFs that document the procedure.
http://www.theminifo...howtopic=167846
hope this helps
Posted 08 September 2010 - 07:54 PM
hi all i want to convert my auto to manual ive got a donor 998 city e with the engine and subframe what else would i need and is there any welding need doing to complete thanks smudge
If you have the subframe and engine available....just swap them over as a unit.
or
You could pull the engine out of the donor and drop it in place of the auto engine....you would just need to install 3/8" spacers on each side of the engine between engine and mounts.
The rod change shifter will bolt right up in place of the auto shifter.
Posted 10 September 2010 - 06:40 PM
and another quick question does anybody know what socket i need to take off the 2 big bolts securing the top of the subframe ive measured it as 1"3/4 and can you get a socket this size thanks
Posted 10 September 2010 - 06:47 PM
Two turret bolts are 1.5/16"
Posted 10 September 2010 - 06:48 PM
Posted 10 September 2010 - 07:17 PM
It's a 3/8" on the clutch side only. Don't bother with the conversion mounts as that is all the one is. You also need to connect the two inhibitor switch leads together.
Posted 10 September 2010 - 08:05 PM
I can speak personally that only putting a spacer in on the rad end does balls it up. Also I don't think the bolt holes line up do they? (was 5 years ago when i did mine!
Posted 11 September 2010 - 02:33 PM
Nope....3/8" on each side is what worked...fits nice.
Ah yes,....one hole on the rad side will also need to be redrilled. Can't remember if the forward or rear one though.
