Mpi, Diy Cylinder Head Is Finished
3 replies to this topic
#1 Scott MPI
Scott MPI
  • 46 posts
Posted 21 March 2011 - 09:44 PM
Hi all
Ive finally finished my cylinder head
Its took a while but im quite pleased with it
New valves
New guides(reamed)
Cnc machined chambers
Bigger inlet valves
All valve seats cut true to guides
Double valve springs
Ported (first attempt)
Bullet nose guides
Back cut valves
Radiused exhaust valves
Matched exhaust ports and manifold
Surface Ground Flat Top, Bottom and manifold face
Attached File  P1010751.JPG   240.94K   83 downloads
Attached File  new_pics_2011_070.JPG   71.11K   45 downloads
Attached File  P1010749.JPG   116.44K   35 downloads
Attached File  new_pics_2011_073.JPG   71.16K   25 downloads
Attached File  new_pics_2011_101.JPG   70.58K   36 downloads
not drove the car yet
i will be geting the car on rollers to see if its any good, the rest of the car is standard so should get a good idea
ill post more pics
#2 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 21 March 2011 - 09:46 PM
Good man, I love a home brew! It's interesting that the rest of the car is standard, I'll be interested to see the difference it makes.
#3 Dylan8660
Dylan8660
  • 206 posts
Posted 25 March 2011 - 11:24 AM
I fancy trying this myself on a spare head. How and why did you get your chamber design?, did much metal come off?, did you skim much to compensate for lower compression if so by how much?. As you had access to a cnc I take it you also used a press for the guides or did you? more detail please.
#4 Scott MPI
Scott MPI
  • 46 posts
Posted 26 March 2011 - 04:34 PM
do it, its been a great project, i got the chamber shape from visards book,it did take a bit off most arount the side a heart, but didnt go to mad just a tidy up around spark plug,the main thing it there all exactly the same with a good radius,the machined finish was good so no need for polishing (the cast chambers i think are very poor)
i took 0.2mm off head
yes pressed guides in, i found they do close in a touch ,so i reamed mine out, i know some people dont
